OK I've almost finished the installation of a new timing belt on my auto R32 gtst, everything until now has gone like clockwork, but I've run into a problem that I can't figure out. How am i going to torque up the main bolt the holds the harmonic balance/ pulley set to the crankshaft?
A friend has suggested I remove the starter motor and jam a screwdriver in the teeth of the flywheel, but that is going to prove a real headache as the inside bolt on the starter motor offers zero room for my socket wrench to move, it might even require removal of the intake manifold.
There has to be an alternate way, if anyone knows of a solution or has some advice I would really love to hear it, otherwise I might have to trailer it to my local garage help.
Cheers Mike.
https://www.sau.com.au/forums/topic/388780-timing-belt-on-a-auto-r32/
best way is with a rattle gun. but most people without a rattle gun just do it up as tight as they can with a breaker bar, giving it sudden, sharp jolts until your sure its not coming off. torque setting: F.T.
Was wanting to use a torque wrench, but I'll be dammed if I'm going to spend all Saturday ripping out the manifold, rattle gun it is then.
Thanks for the reply.
Hmm might be worth one last shot, I only have a standard 40 piece sidchrome socket set, if I can source a couple more 250mm extensions then I'll give it a try. Just went outside with the torch and there is a gap between the alternator and the block, with a bit of luck it won't foul on the oil filter or pressure sender.
Autobarn or Repco carry a ring gear stopper?
Thanks again, Mike.
Remove the starter and fit a ring gear stopper.
It's not a GTR so the starter is easy to get at.
Use a long socket extension and come from the front. Easy as.
Hit the nail on the head mate I swapped the starter in my 32 in a few hours mate think outside the box a lil and u will get it out :-)
I can fit the ring gear stopper on the GTR in a couple of minutes.
No need to actually remove the starter from the car, just disconnect the battery terminals, remove starter bolts and swing it clear, cables and all.
Remove the difficult bolt completely first before you slacken off the easy one.
450 long x 3/8" drive universal extension can be bought from any tool supply, then add shorter extensions until you clear the alternator and can swing the brace.
I made my ring gear stopper, not difficult but in my opinion it's essential considering the torque required on the Rb26 balancer bolt. ( 330-340 ft lbs)
I have heard that one of the clutch slave cylinder holes lines up with the ring gear. A modified long bolt with the end machined down can then be screwed into the hole and engaged in the ring gear.
Not for me but a GTSt has a LOT less torque (105-115 ft lbs) on the balancer bolt so it could suit your situation.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
