OK,
Been having ongoing problems with the 4wd system in my R32 Gtr.
Normally, everything is fine.
Lights on and pressing brake pedal bring the 4wd light on. Checked ecu in the boot, 21 flashes.
Recently I got hold of a pfc hand controller, checked the tps signal. Was around 0.60v
While checking, I noticed that the tps voltage would go up when the lights were on and when brake pedal was pressed, i'm assuming that's not right.
Could be a grounding fault?
Anyone else had a fault like this?
https://www.sau.com.au/forums/topic/389028-4wd-fault/
exacty same thing happens to me
i found a couple of earths that were a bit dodgy and sanded it back... this did fix the problem for a while, but it came back again :angry: ,
If you figure it out for god sake let me know what it is lol
I find it does the same thing when u hold the power window buttons down when they are already down.. seems like it gets a large current draw and drops the awd for some reason
https://www.sau.com.au/forums/topic/389028-4wd-fault/#findComment-6200785
cleaned up the main battery earth
i also had some fookin weird custom earth job from the bloke before me the conected to the strut tower...
i think he had tried to fix the same problem by getting a new battery and alternator... obviously didnt help
Edited by GTR_JOEY
https://www.sau.com.au/forums/topic/389028-4wd-fault/#findComment-6200812
its a f#uckin pain in the arse is what it is...:rant:
pretty much cant drive at night and pull up to a set of lights without the awd dropping out
let us know how u go and if anyone else has any ideas it would be much appreciated
btw im also running a PFC, maybe that has somthing to do with it?
im changing to a LINK soon so we will find out!
Edited by GTR_JOEY
https://www.sau.com.au/forums/topic/389028-4wd-fault/#findComment-6200845
Check your alternator is up to the job.
GTR's draw a lot of current, specially when the ATTESSA pump cuts in.
Most old GTR's have lost the charge in the accumulator so the ATTESSA pump runs way too much.
Add the wattage of headlights, stoplights, wipers and so on then see how much the alternator is pumping out on idle, you may be in for a shock.
Remember the alternator's rated output (90amps) is not at idle.
Mine couldn't keep up, ATTESSA light would come on periodically as it pumped up pressure.
Changed to 35W low beam HID's and that gave me enough headroom for everything to work OK.
Still it's a sign that in my case the original 21 year old alternator is getting a bit sad.
https://www.sau.com.au/forums/topic/389028-4wd-fault/#findComment-6204056
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
