I have a full set of rb20det coil packs in the metal frames from my car. I put some FET coil packs in so i have no need for the stock ones.
Im after $170 for the full set or $40 each. I don't mind seperating them as one or two spare could be handy if the FET's pack it in.
In brisbane and will post interstate.
Cheers
Jayson
0401669900
[email protected]
https://www.sau.com.au/forums/topic/38917-fs-rb20det-coil-packs/
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
