Hi, I've been trying to get my RB25DET S1 started as it's been sitting around for a few years, so far i've cleaned the fuel tank, put in fresh fuel and she's turning over but not even a hint of spark, i've took the CAS off and turn in while ignition is ON and when I do the fuel pump activates but I cant hear the injectors clicking
I found an awesome post by Elite (below, HUGE! thanks btw) but being a noob im a bit confused, i'm about to check the plugs/coil packs for spark individually as outlined in the post, but would like to clarify how exactly i'm ment to check power to the coils, will i disconnect the plug from the plug and check the voltage to the wires or can this be done without removing the plug/coil??
You need to have checked ALL of the following properly:
Spark on ALL cylinders
Injection pulse on ALL cylinders
Compression
Fuel pressure
Check engine bay fuses and under dash fuses. With a 12v test light - don't just eyeball them from 1ft away
IF you have missing spark on any cylinders, check power to coils. If you have 12v then check earths. If you have good earths as well then swap coils to see if the spark moves to a different cylinder (only if you have spark on at least one cylinder to begin with)...otherwise swap them all out and check spark again. If you have no spark, but have 12v, check CAS signal (see below) and then check continuity back to the ECU
IF you have no pulse, check 12v at injectors - ALL OF THEM. If you have 12v but no pulse then check CAS trigger signal back to ECU with a scope or check RPM signal in ECU. If you don't have a scope you can swap CAS out but that's a dodgey way to check it. There is such a thing as two broken CAS's in the world. If you still have no pulse and a good signal from the CAS, then check continuity back to the ECU on both wires to make sure there is no breaks. If continuous back to the ECU on both wires - replace ECU
IF you have no compression - rebuild
IF you have no fuel pressure, remove the fuel filter and check it with a gauge (no exceptions - gauge or take it to a mechanic), If you have no pressure still with filter off, check 12v to fuel pump while priming. If no 12v is present then run a dummy wire to the boot and see if it fires up. If you have 12v but no pressure, then replace the fuel pump
If you have spark and injector pulse ON ALL CYLINDERS, fuel pressure, compression, no blown fuses and it still won't start, put some new spark plugs in it because you have probably fouled the shit outta them. Any plug will do. 4's will work. 9's will work. As long as they are new and they are a spark plug that fits
When you can put a tick next to EVERY item, then we can continue but I can assure you, if you perform all those test you will find your problem. If you don't do even ONE of those things, don't come back here asking for more help. Those are all the things you need to find your problem. If you don't have the equipment, borrow it or take it to someone who knows what they are doing. There are plenty of good import mechs in Victoria
EDIT** - One more thing, physically check ALL hoses for splits or if they have come off. If you are not sure, remove them and reattach them to be sure. You will cancel out the possibility of a major air leak AND you will learn a lot about your car at the same time
https://www.sau.com.au/forums/topic/389265-rb25det-fault-finding-help/
futhering testing shows ECU fault code 55 (good to roll) and tested the spark plug closest to the CAS sensor is getting good spark, so from what I can gather due to spark but no injector pulse and no fuel smell from the cylinder after cranking when the plug was out is that it's fuel related... unless I've missed something?
A quick history of the car might help to explain whats happend...
The RB25DET is in my 180sx and I upgraded the S13 pump to a Bosche 040 intank pump, this required the earth lead to be grounded near the pump to give full voltage, the car ran well for after the install but over time cold start took longer to fire up, i've connected the pump directly to a power supply and it seems to provide a consistent fuel (no spluttering etc) but havent had it tested, i've also disconnected the feed line into the engine after the fuel filter and get the same solid flow of fuel.
Is there a way i can test the injectors with taking them out so I dont have to replace the O rings?
And what would be causing the injector's not to pulse?
Use a test light to see if there is power at the injector plug when the key is on. 1 wire on all injectors should be powered. Will be the same colour on all injectors.
Then u need a noid light or LED test light to see if the negative trigger (the other wire on each injector plug) has a signal from the ecu when cranking.
Let us know how u go and will tell u what to try from here
If you have 12V at the injectors and they are getting a pulse (tested with noid light - available at any repco or autobarn for about $10-$15) but the injector is not delivering fuel, the internal solenoid is seized. Now this is a tricky one - not difficult in practice but a difficult scenario for me to offer advice on - you can lightly tap the body with a screwdriver and hammer to try to activate them (get a friend to rotate the CAS while you do so it is trying to fire at least). Sometimes the jolt will free them up. If they free up, I HIGHLY recommend taking them out and having them cleaned and flow tested. Injectors that have sat for months will usually always seize unless stored in lubricant or fuel (bad). If you tap them, they start working and you can drive your car....I take no responsibility for melted pistons because you didn't take them somewhere to have them cleaned and checked. The fact they were seized means they cannot be trusted.
+1. Whenever I do an engine conversion I ALWAYS have the injectors cleaned particularly if the engine has not been started for an extended period. I upgraded the fuel injectors on my car once with some second hand injectors and had them cleaned before installing them and all 6 were found to be either completed blocked or substantially blocked. Good advice worth considering.
I have tested power to the injector on the closest injector to the CAS and all is good
I made a noid out of a 200k resistor and an old LED i had lying around and it seems to give a solid pulse when cranking, just about to try the rest of them now. If they are all pulsing, then thats either seized/clogged injectors and they need cleaning or replacing right?
I want to upgrade the injectors anyway, so i could just buy new ones, i assume a remap of the ecu is a requirement?
If you correct fuel pressure, power to injectors and pulse, power to coils and spark but the injectors are not ticking when you turn the CAS over by hand with IGN on, then yes, most likely cause is seized. give it a little tappy, tap tap taparoo.....
or just replace them yes
Update: All injectors tested ok for power/pulse, so i found some enthusiasm and pulled off the plenum collector and took off the injector rail, rather than getting stock ones i wanna get some 500cc+ injectors, i was looking at the safc II as a temporary measure until i get the cash to get a PFC.. but just out of curiocity, would driving around off boost cause issues with the larger injectors installed (as in drive it 30min to the tuners)
    • Had another look at the car and I noticed the fuel pump isn't priming on ignition. I'd taken out the pump from the boot to siphon out the old fuel, so maybe I've knocked something loose or broken a wire putting things back together. Will go back with a multimeter and try to work out what's stuffed. Kinda hoping it's the pump itself thats gone so I can upgrade it
    • Yeah agreed, you can't assume that shop are they only people who ever had to work on it. It was just a guess on the mods based on how things were done back then. You can check the Air Flow Meters by the part number on their tags, they are likely either Z32 or Nismo ones (both read about the same but the Z32 one is a little larger while nismo is stock size but supports the higher airflow like a Z32). And yes, all that would get you to 450hp / 340kw To tell what is happening with the turbos, you want a photo of the tag on the core, that will say what it was made out of  (they can retain the front and rear covers to make the plumbing easier)
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is juan@bardabe.com
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
