SUB-ZERO - RB25DET Intake Plenum & Throttle Body
For sale is a custom polished Subzero plenum that is welded to the standard RB25DET runners, it has fittings to suite the standard vacuum/air lines.
HIGH RESOLUTION: pic 1, pic 2, pic 3, pic 4
The throttle body is 90mm, the nut has been modified so the stock TPS can be used, however this can easily be replaced with a standard nut if it's not required, as it stands it is literally a bolt on replacement of the stock unit.
HIGH RESOLUTION: pic 5
This is a photo showing the TPS adapter fitted.
HIGH RESOLUTION: pic 6
If you haven't heard of SUB-ZERO they were an Australia tunner who apparently have moved to Dubai now, they were responsible for a few insane 9 second Skylines (try googling PVL 747: 9 second pass, try9s: 9.5 second pass)
I'm selling this as I decided to revert the car back to stock for use as a daily. I would of loved to see it's full potential but will have to leave that up to the lucky buyer.. this plenum is simply stunning and is a very regretful sale, buyer will not be disappointed.
I am located in Tarneit, Victoria and can be contact on Mobile: 0427 350 666 or via email: [email protected]
$950 ONO
thanks,
Gareth.
Edited by nismad
  • 4 months later...
  • 3 months later...
