MAKE: NISSAN 200SX S15 VARIETTA CONVERTIBLE 2 DOOR COUPE
COLOR: METALLIC SILVER
TRANSMISSION : 4SPEED AUTOMATIC
ENGINE: 4 cylinder Petrol Aspirated 2.0 L
KILOMETERS: 80,000km
Hard Top Roof Convertible - Roof folds into boot
Leather Interior - Front and Back Seats, Wheel, Gear Knob and Dash
Original Nissan Floor Mats
Air Conditioning
Sony Xplod Head Deck
Pioneer Front Speakers
Aftermarket 18" Gold RE Rims
Has just been fitted with a new sports muffler with a 3" exhaust tip
New aftermarket rear tail lights
Second owner, the car was bought from dealership comes with log books. Recently serviced Nov 2011
Only few of these cars have been imported and is a very rare find not many of these around at all. Its very unique and grabs attention everywhere she goes.
Very enjoyable to cruise in with the roof down, Have been stopped so many times with people asking about and taking photos of her.
Contact
Chrissy
0435 761 500
https://www.sau.com.au/forums/topic/390684-wts-nissan-s15-varietta-convertible/
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
