Hi every1,
Im looking for an R34 GTR, either vspec or vspec II - excellent condition and bayside blue in colour.
A close to stock one is preferred, but will still consider modified examples.
I am located in Sydney but may travel for the right car. Have cash ready.
If u have one, please PM me your contact number and a brief description of your car + asking price and we'll go from there. Or If u would like to call me my number is 0403 898 517.
No carsales links please, already check there regularly. And please No broker / importer / dealer offers - unless the car is already landed. I already have people looking in Japan 4 me.
Thanks.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
