P-Plate Legal Non-Turbo
<br style="font-family: Arial, Verdana, helvetica, san-serif; text-align: left; ">
This car has been the focus of a LOT of love and attention over the past 9 months or so. It is amazingly clean for its age and I hope it goes to an owner who respects it for what it is.
I am looking to swap the 180 for any of these vehicles in varying conditions so DONT BE AFRAID TO MAKE AN OFFER FOR SWAPS
-R32 4 Door, R34 4 Door, C33 Laurel, JZX81, JZX90, JZX100, s13, s14 - Don't mind cash either way. Will even consider 32 4 Door Rolling shells.
I am quite firm on $10,000 w/o RWC (because of locker/low)
SR20DE - 130,000kms
Chassis - 120,000kms
HKS Extractors
Hi-Flow Cat
2.5" Stainless Exhaust with Cannon
15Degree Lock Spacers
Castor Rods
Rolid Steering Rack
Pod filter relocated to left hand side - cold/short intake
R32 GTR SwayBar (Thick)
Rear Strut Brace
PowerByMax Adjustable Camber
PowerByMax Adjustable Toe
Cusco Cambertops
Tien 2 Way Adjustable Coilovers
17x9+12 Rota Grid {Gunmetal} Fronts with 215/45/17 Federal RPM's
17x9.5+12 Rota Grid {Gunmetal} Rears with 215/45/17 Federal 595's
Heptagonal 12x1.25 Steel Wheel nuts (Anti-theft)
Type X Front Bar
Type X Side Skirts
Standard 180sx Rear Bar
Lazy Eye Pilot switch
R200 LSD with Genuine Nissan LSD Shims (Locker) Proffessional Heel and Toe alignment.
Rolled front and rear gaurds.
Custom made Extra Heavy Duty Clutch with loads of Cushioning. NPH
<br style="font-family: Arial, Verdana, helvetica, san-serif; text-align: left; "><br style="font-family: Arial, Verdana, helvetica, san-serif; text-align: left; ">
Interior:
300W Amp
15" Sony Sub
Alpine Head
iPhone Aux Line
Nismo Gear Knob
Mint DashBoard, No Cracks
Digital Climate Control
No rips, tears, stains - The perfect cockpit.
I bought this car to use as a daily and to take to track days at QR. It was SR20DET - stock and since then has been upgraded with the parts list above. Alot of weeks, sweat and blood have been put into this vehicle.
Edited by Rusty_RB
https://www.sau.com.au/forums/topic/390989-180sx-non-turbo-for-saleswaps/
  • 1 month later...
  • 6 months later...
Hey mate I'm looking to part with my r32 four door and am desperately looking for a 180 or s13 non turbo please see the link to my for sale thread
http://www.skylinesaustralia.com/forums/topic/410562-r32-four-door-drift-car/
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
