Hey guys,
Looking into opening a business, just had a few questions about the lease, and general questions one would have with opening in restaurant/cafe type business.
Wondering if anyone on the forums was a commercial lawyer or has a restaurant that would be able to help me and my business partner out and offer some pointers or answer any questions we had.
You can contact me on the phone or email. Or if you are free to meet up and have a chat over coffee.
Calls before 5, email anytime.
0439990557
[email protected]
Thanks George.
https://www.sau.com.au/forums/topic/391046-commercial-lawyer/
The lawyer would be to handle the lease if your starting your own business wouldn't it? If your buying an existing one you'd also want someone to thoroughly check the books ie an accountant
Commercial leases are typically straight forward as the tenant pays for rent & outgoings fit out etc you'd want a rent free start up period and depending what and where your going what promotion the centre will be doing to attract customers etc
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
