post-78613-0-10419700-1328810287_thumb.jpgpost-78613-0-10419700-1328810287_thumb.jpgBought my r34 recently and it has 20 inch chromies on it and not loving the look at all! so im looking to swap for some cheap rims and was looking at 350z stockies (17inch ones) or gtt stockies (seem a lil small for my body kit)
Tell me what you guys think ! Have a feeling the 350z rims might look out of place..
Edited by calebR33
https://www.sau.com.au/forums/topic/391181-cheap-rims/
