sorry, i should of reworded that
my reference to the stagea guys on here was due to their recommendation, support and past group buys.
these kits are to suit any car.
Edited by seohyunjin
forgot to post specs for those who asked:
Features
DVB-T Reception
Best in class performance of DVB-T TV reception (Diversity-2)
Multimedia playback
MP3, MPEG4, JPEG multimedia playback through USB device
Advanced functions
Support TV-recording (record on USB device) and AFS function
RF Input
Antenna
Passive and active antenna supported.
F-type antenna
Frequency range
VHF (170-230 MHz) and UHF band (470-862 MHz)
RF input impedance
75 Ohm
Channel bandwidth
6/7/8 MHz
TV System
Transmission standard
ETS 3 00 7 44 DVB-T compliance
Video/Audio decoder
MPEGII
S/W Feature
OSD Language
English, German, French, Portuguese, Spanish, Italian, Dutch, Finnish, Traditional Chinese, Simplified Chinese
Features
DVB-T TV/Radio, Auto Channel Search, Multi–Language EPG, Channel Preview, Teletext, Subtitle, Auto Frequency Switch (AFS_
TV/Radio Recording
Record TV/ Radio programs on USB device
Media format
Audio format
*.mp3, *.wav
Video format
*.mpg, *.dat, *.vob, *.avi (MPEG4 ASP, XviD, DivX4.0/5.0)
Photo format
Recorded File Format
*.mpg (TV recording) and *.mp3 (Radio recording)
Interface
External AV input
2 sets of A/V inputs (2 x three-port RCA jack)
A/V Output
3 CVBS Video Outs, 1 Audio (L/R) Out
USB Port (storage source)
To store real-time TV/Radio-recording
Host USB 2.0 supported
Infrared Remote Control
Supported through IR Extension Dongle Cable
Power
Input voltage
12-24 V DC
Power consumption
3.5 W
Dimension and Weight
Dimension
175 x 131 x 25 mm
Weight
580 g
including pic of main unit:
image of unit working:
it is a complete kit which includes TV tuner and all required peripherals.
  • 4 weeks later...
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
