sorry, i should of reworded that
my reference to the stagea guys on here was due to their recommendation, support and past group buys.
these kits are to suit any car.
Edited by seohyunjin
forgot to post specs for those who asked:
Features
DVB-T Reception
Best in class performance of DVB-T TV reception (Diversity-2)
Multimedia playback
MP3, MPEG4, JPEG multimedia playback through USB device
Advanced functions
Support TV-recording (record on USB device) and AFS function
RF Input
Antenna
Passive and active antenna supported.
F-type antenna
Frequency range
VHF (170-230 MHz) and UHF band (470-862 MHz)
RF input impedance
75 Ohm
Channel bandwidth
6/7/8 MHz
TV System
Transmission standard
ETS 3 00 7 44 DVB-T compliance
Video/Audio decoder
MPEGII
S/W Feature
OSD Language
English, German, French, Portuguese, Spanish, Italian, Dutch, Finnish, Traditional Chinese, Simplified Chinese
Features
DVB-T TV/Radio, Auto Channel Search, Multi–Language EPG, Channel Preview, Teletext, Subtitle, Auto Frequency Switch (AFS_
TV/Radio Recording
Record TV/ Radio programs on USB device
Media format
Audio format
*.mp3, *.wav
Video format
*.mpg, *.dat, *.vob, *.avi (MPEG4 ASP, XviD, DivX4.0/5.0)
Photo format
Recorded File Format
*.mpg (TV recording) and *.mp3 (Radio recording)
Interface
External AV input
2 sets of A/V inputs (2 x three-port RCA jack)
A/V Output
3 CVBS Video Outs, 1 Audio (L/R) Out
USB Port (storage source)
To store real-time TV/Radio-recording
Host USB 2.0 supported
Infrared Remote Control
Supported through IR Extension Dongle Cable
Power
Input voltage
12-24 V DC
Power consumption
3.5 W
Dimension and Weight
Dimension
175 x 131 x 25 mm
Weight
580 g
including pic of main unit:
image of unit working:
it is a complete kit which includes TV tuner and all required peripherals.
  • 4 weeks later...
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
