Hi for sale
Nismo cannon $150
brand new Drift cannon $100
big Drift wing $250
rear springs $90
front right side spring $50
front left side spring only. $30
R33 dash $25
R33 rear back light cover $15
cross over pipe for intercooler piping $20
R33 wipers a set of 3 $25
brand new wheel studs $30
Rb25 stock plenum with out water pipe and with A/C just plenum only $30
R33 rear back cover that says skyline go's under the boot $10 needs a paint job
R33 inside boot carpet that hides the lights wiring $15
R33 GTR genuine wing with brake light and full adjustable $400
R33 M-spec front bar $300
will post if you organize the posting and pick up
Thanks
Edited by MAD R33
https://www.sau.com.au/forums/topic/391268-r33-parts/
the crossover pipe, is it alloy and odes it have a nipple? Put in a new fmic and my new alloy crossover pipe doesn't have one, am running my wastegate off my boost controller line at the mo. Would be interested in just the nipple so I can get it welded onto my current pipe...
https://www.sau.com.au/forums/topic/391268-r33-parts/#findComment-6235888
https://www.sau.com.au/forums/topic/391268-r33-parts/#findComment-6235890
No sorry
https://www.sau.com.au/forums/topic/391268-r33-parts/#findComment-6247318
for sale Nissan R33 Skyline RB25DET Cast Turbo Exhaust Manifod
sell for $250
for sale
R34 Skyline Traction Control Throttle body came off rb25det neo Auto
sell $50
For sale
NISSAN SKYLINE TRANSMISSION 2WD AUTO RB25DET NEO
got it with a motor but don't need is as my car is manual
For sale RB25det S1 motor comes with turbo Loom and everything you need to bolt it in no ecu or afm sell for $600 need's rebuild i think as number 5 cylinder is not working...
https://www.sau.com.au/forums/topic/391268-r33-parts/#findComment-6258088
  • 3 weeks later...
    • Started sifting thru my brakes to decide which ones I will run on Clem   Made me think I should just put them all on Silver...for when brake fade just isn't an option   Should be able to bump rotor up from 343x32 to 348x36 off Supra. Not sure if the Supra annulus is right for the Alcons or APs but trying g to find a used Supra\M4 rotor to test fit The Alcons seem to gain 1-2mm clearance which all helps
    • So car is getting a few mods to the cage and some jacking points welded in Meantime Ol Silver gets a new gearbox and shiny clutch.  Old Box is being set aside for Clem
    • Probably speedometer itself if the odometer is ticking. If the needle is stuck from a bit of grease or something that can cause it to stay at 0. Or a cracked solder joint in the speedometer can do it too.
    • Thanks Fella’s   to take this off topic and to elaborate a bit more. I have an rb25/30 going into a r32 GTST.. expected to make around 600-700hp. Would you?   A) R34 GTT box   B) CD00#?  I’ve seen a few posts about the CD swap and sounds fairly involved with making it fit etc but if it’s worth the work then I’ll go that way
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
