Hi all.
Replaced my fog lights with spotlights, so have some spares that might be useful to others.
I have...
2x Cibie reflectors with bulbs etc
1 x Cibie glass lens
Note that I have NO mounting hardware at all, but this would be useful if you have a broken fog light and you can reuse your existing mounting gear.
Also have two H3 bulbs and wiring from the new spotlights, as I put a HID conversion kit in.
Not sure what its worth. Beer?
https://www.sau.com.au/forums/topic/391474-m35-fog-light-parts/
Turned out ok actually. Only thing I have to do now is work out how to rewire them - the standard wiring won't allow high beams and 'fog lights' on at the same time.
I moved the car into a more picture friendly spot this morning, I'll get some tonight. I think it looks pretty good, but it does need some tidying another day. Just to try and clean all the silicon out.
I have had a PM already, but I'll let you know.
Yeah thats what I figured. You don't happen to know where they need to go do they?
I guess fog lights and high beams on at the same time doesn't happen. But who drives around with spotlights and no high beam? If you need spotlights, you probably need high beam.
Oh, and these are SOLD.
the relay at the airbox can be modded so you can have driving lights, or driving lights AND integrated fog lights.
with the relay and the diode, you need to apply power to the fog light circuit when the hi-beams are on. you can do it behind the stalk as i believe thats where its switched.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
