Please contact on 0434 052 990
May post interstate depending on the item & where to, at buyers expense
Performance Parts -
Brand new HDI GT2 Spec Intercooler With 2.5" Piping - $550.00
HKS 19 Row Oil Cooler with Oil Filter Relocation (all braided lines) - $300.00
Brand new Blue Silicone Induction pipe - $75.00
Stainless Twin 3" Rear Straight Pipes Diff Back System - $200.00
3" De-cat Pipe - $50.00
3.5" Front Pipe - $125.00
R33 RB25det Series 2 Cam Shafts - $75.00
Exterior Parts -
Nismo R33 Z-Tune Carbon Fibre (suit any model R33) - $850.00
Nismo 400R Carbon Fibre GTR Spoiler Blade - $400.00
Brand new SRI Carbon Fibre Canards - $100.00
Other Bits/Accessories –
Mines Racing Japan Turbo Blanket - $50.00
R33 Series 2 Spoiler - $125.00
R33 Series 2 Rear Pods - $50.00
R33 Pod Filter Air Box - $75.00
photos upon request
Everything's brand new or less than 2,500km & Less than 4 weeks old
Items suit r33 series 2 rb25det - Some parts may fit other makes/models
Edited by xclusiv
Performance Parts -
Exterior Parts -
photos upon request
Front pipe is 3inch not 3.5 thanks
Edited by xclusiv
hey mate dnt wana kill ur thread but after msging u n getting pics of the oil cooler I did tell you to update ur ad as it was a cooling pro oil cooler kit and not a hks core or anything..
http://justjap.com/store/product.php?productid=16879&cat=&page=1
http://justjap.com/s...879&cat=&page=1
i have notified buyers that have contacted me about it. just haven't had time to update, however yes it is the oil cooler listed for future buyers
sorry for not updating ealier
Straight Pipe Sold
Items still for sale
Performance Parts -
CP 19Row Oil Cooler with Oil Filter Relocation (all braided lines) - $300.00
Brand new AB Blue Silicone Induction pipe - $75.00
3" Front Pipe - $125.00
R33RB25det Series 2 Cam Shafts - $100.00
ExteriorParts -
Nismo R33 Z-Tune Carbon Fibre Bonnet (suit any model R33) - $850.00
Other Bits/Accessories -
NismoFront Strut Brace with Master-Cylinder Brake Stopper - $150.00
MinesRacing Japan Turbo Blanket - $50.00
Pleasecontact on 0434 052 990
Maypost interstate depending on the item & where to, at buyers expense
Need these gone
Edited by xclusiv
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
