Okay - here we go with Pics.
Catco - $100 - ($175)
Front pipe - $200 - ($395)
Kaki Regu 06&R - $600 - ($1095)
All pretty much half price, or Package for $750
Less than 4000kms.
All in perfect nic except cannon has minor scratches on underside.
You buy my stuff
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
