hey guys im looking at getting a internal waste gate for my gt3076 as its a external gate model and im selling the rear housing and buyin a internal wastegate one
just wondering if anyone has seen or played with this internal wastegate seems to look pretty nice with the extra springs to go inside for desired boost levels
http://www.ebay.com.au/itm/Kinugawa-Adjustable-Turbo-Wastegate-Actuator-Garrett-GT3071R-A-R50-3-Spring-/270912634695?pt=AU_Car_Parts_Accessories&hash=item3f13a6bf47
just wondering how it would hold up boost as ive been told to get the 14psi garrett actuator but this one is a bit cheaper just wondering if it might work the same
Thanks guys
https://www.sau.com.au/forums/topic/391896-kinugawa-wastegate-actuator/
oh really are they the same as this one
any suggestions im goin internal gate for now just cause i bought a dump pipe and everything to suit off another member
i was looking for a actuator with a minimum of 14psi :) so hopefully theres no boost spike issues and im not sure if the rear housing im buying comes with the brackets and everything
I'm not turbo expert but I'm guessing Garret will give you the quality needed that 100 bucks could save thousands. Call gcg up I'm sure they will have one to suite
Edited by Bsa
yeah ill get the part number off them and get it from garrett direct cut out the middle man hahaha
hey just wondering i bought the mafia's dump pipe he had on his car with the gt3076 later down the track would it be able to weld the stock internal gate closed and weld a external to the manifold or is there no point as im only wanting to achieve 280-300 :) on bp98 thanks dude
ive seen a fair few results on here with the 56t .82 on 17-19psi internal gate make 280-300
the mafia made 315rwkw
i cbf getting a new dump pipe made up as im buying everything so its only a day job to put it all together
i was considering external gate but ive seen results pretty much the same using internal vs external with the .82 rear
when it comes to the .63 external for sure
I went in Mick_o's 33 with the .82 internal gate GTX3071 and can say the Garrett actuator does its job well.
The car was rapid and had really good boost recovery. I wouldnt think twice about going Garrett if its an option for you.
Blake I think the reported Kando issues are more around the housings than they are the actuators. Ive used a few of their actuators now and they work fine :thumbsup:
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
