Located in Boronia (SE Melb), happy to freight at your expense
Complete GTR for wrecking minus the following:
- Wheels
- Complete Motor & Gearbox
- Exhaust
- Brakes
- Front Hubs
- Front Seats
- Fuel Tank & Pump
- Steering Wheel
- Radiator
- Steering Rack
- Driveshafts
- Dash Surround
Here's a start:
- Diff - $400
- Rear Driveshafts - $200 pair
- Rear Hubs - $200 pair
- Rear Subframe - $200
- Tailshaft - $200
- ATESSA 4WD PUMP - $200
- Space Saver - $100
- Boot Lid with Wing - $400
- Rear Bar Skin - $200
- Rear Reo - $150
- Tail lights - $200 pair
- Rear Garnish - $150
- Boot trim - $200
- Sideskirts - $400 pair
- Rear window - $250
- Rear 1/4 Glass - $150 each
- Front Glass - $150
- Door - $250 each
- Door Trims - $150 each
- Mirrors - $150 each
- Electric Window Motors - $150 each
- Glass front doors - $150 each
- Driver Electric Window Switch - $100
- Passanger Electric Window Switch - $50
- 180km instrument cluster - $250
- Centre Console Gauge's (3) - $200
- Complete Set of Locks + 2 x GTR KEYS - $250
- Floor mats (5) - $150
- Rear Seats - $350
- Dash - $250
- Centre Console - $200
- Rear 1/4 Trims - $150 each
- Carpet - $200
- Seat Belts - $50 each
- A Pillar Trims - $50 each
- Roof Lining - $150
- Standard GTR struts $250 set
- Standard Front Swaybar - $50
- Standard Rear Swaybar - $100
- Standard upper arms - $150 pair
- Standard uprights - $150 pair
- Standard lower control arms - $150 pair
- Standard castor rods - $50 pair
- Front Crossmember - $250
- Front Guard Lining - $250 pair
- Series 3 Brake Air Ducts - $250 pair
- Air Con Condensor - $150
- Air Con Compressor - $150
- Air Con Drier - $50
- Air Con Lines - $150
- Standard Intercooler - $350
- ABS Unit - $350
- Intercooler Piping - $250
- Standard BOV's - $250
- Standard Washer Bottle - $50
- Overflow Bottle - $50
- Heater Core - $150
- Front Strut Brace - $150
- Rear Strut Brace - $150
- Front grille - $250
- Damaged Bonnet - $350
- Damaged Driver Side Guard - $200
- Damaged Driver Side Guard Raiser - $100
- Passanger Side Guard - $300
- Passanger Side Guard Raiser - $150
- Standard Side Indicators - $50 pair
If there's anything i've missed just shoot me a PM.
Chris.
  • Replies 190
You wouldn't have the two front lights in descent condition, would you?
i wish! there's a few bits i've kept from the driver side headlight, the passanger side which u can see in the pic is repairable but it's cracked all the way through and right around, mostly good for parts thats about it.
if anyone wants a pic of the RHS headlight PM me your mobile number i'll mms it to you
Two PM's from me.
working through the pm's now you'll have response soon
Selling that front mount?
not that one, but i have a standard one if your interested
Airbox and snorkel? Pm me
nope,,
Does the k-frame look bent? I might be keen plus any front control arms and knuckles that look ok. I dom't need the brakes
the k frame shifted on its mounts a mm or 1/2, i wouldn't say its bent though. the nismo lower control arms im keeping, i have standard arms from another car if you like, hubs are gone, brakes im using.
what do you mean by knuckles? thats the hub and knuckle, have a look in the pictures, i have standard uprights for sale, and standard upper arms
Oil cooler assy?
sorry i thought i got everything but obviously not, the oil coolers not for sale.
i bought the car below, so i have 2 of everything, minus motor and gearbox and go-fast bits, so mostly all stock parts.
http://www.skylinesaustralia.com/forums/topic/327477-33-gtr-skylinegenuine-vspec-less-topend-clutch-calipers-10900/page__hl__r33+gtr+shell
Just PM.
hey, replied to all,
Hey mate, do you have a list of what you got left off of the silver GTR?
the silver GTR was missing alot of parts, and a lot of parts which were stock have been replaced with aftermarket.
i dont have any aftermarket parts for sald, mostly an entire standard car worth of parts minus engine, gbxox, and brakes.
if anything in particular you are after shoot me a PM
Mate rear sub frame in what condition is it.
I'm chasing one and must be straight and no rust.
Only need the frame, no arms etc.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
