Skyline Op6 Highflow Turbo, Exhaust, Bc Coilovers, Cat, Hks Pod, Hks Boost Controller, New Bosch 040 And More
Hi guys,
I'm putting up for sale some parts off my car that I have recently put back to standard as I will be selling the car. All parts have less than 10,00k's on them and some even less than 5,00k's as the car was not used as a daily. Can organize postage at buyers expense and can organize times to look at the parts.
Call Daniel on 0405004111 or PM me if your interested in any of these parts
1. OP6 High flow turbo, bush bearing, no actuator. Bolts straight in and looks standard, don't know the exact size but it is good for 230-250 Kw at the wheels (obviously depending on what supporting mods you have). Done around 6,000k's since rebuild with these internals, in perfect condition, never had any issues with it and was working perfectly in my car before I took it off. I know it will fit R33 and 34 for sure, not 100% sure on R32 so you should check yourself. $700 ono
2. BC BR series coilovers, 8/6 spring rates, base height adjustable, 32 was compression/rebound adjustment, Fit R33 GTS25T. Done around 5,000K's on these and they are in great condition and never been used on the hardest setting so nothing is blown. Good combination for street and light track work. I bought these new but will sell for $850 ono
3. Genuine Bosch 040 fuel pump, brand new, never been used. Comes with wiring, fuses and relay and hose clamps as per the recommended instillation guidelines. $200 ono
4. HKS EVC 4 silver edition, comes with controller, harness, line filters and actuator. Used for around 10,000k's, works well and has an overboost warning and cut off so good backup in case something goes wrong. Everything works well and can be used with internal and external gate, $290 ono
5. some other random parts;
-JJR 3" stainless steel bell mouth dump pipe for R332/R33 $130ono
-CATCO 3" high flow ceramic cat for S13, Z32, R32/33/34 $120 ono
-HKS pod filter with BOV plumb back attachment, bolts straight onto the AFM for R32/33/34, Z32 and S13/14/15 $30 ono
-NEOTECH rear camber arms for R33, R34, S14 and S15, 5,000k's done with them, $90 ono
who was the turbo rebuilt and hiflowed by mate? and do you have the receipt for the work?
Any dyno sheets showing power/ boost level?
Never had the car on the dyno as I never put an aftermarket computer on there. I had a friend who was running the same turbo on RB25 and he was making around 250 RWKW on somewhere around 20psi, but this is all depending on your supporting modifications of course.
Hi guys,
Dont know how to add this to the post but I have said 6,000k's on the rebuild but it is actually around 10,000k's. Sorry for the mistake
everything is still for sale except the dump pipe and the cat, pm me if your interested any any of the other items
  • 3 weeks later...
Hi,
I am just about to buy some new BC coilovers but may consider used items if the price is right. I notice you say "Done around 5,000K's on these and they are in great condition and never been used on the hardest setting so nothing is blown." From that comment I assume that they blow the seals out if set to the harder setting? Thats OK, I only need them for street use and will keep them on the softest setting. Considering that they are only good set for soft use on the street and will likely fail if set for any harder, I think they are worth offering $400.
Kind Regards
Black_R33
Hi,
Kind Regards
Black_R33
Hi there,
I say this as I have heard of people blowing there coil over by having them set to had and hitting big bumps, i only used them for street use so I am just saying they are in full working order with no problems. They are more than capable of being used on harder settings just like a now set of coilovers so I believer my asking price is pretty reasonable as a $1300 set of new ones is going to be in exactly the same condition.
Thanks,
keen on the dump pipie and poat.to 2880
cheers
Hi Mate,
Sorry but the dump pipe and the cat have both been sold together.
Thanks,
040 and associated items have been sold.
Boost controller, pod and coil overs are still for sale
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
    • To re-cap, I bought: https://www.alibaba.com/product-detail/Lsailt-8G-Infiniti-Q50-Q60-2014_1601171829627.html?spm=a2756.trade-list-buyer.0.0.2cd476e9FTIlKE As you can see, if I bought 20 it was $653, but I bought 1 so it was $1,170. I was very tempted to buy 2 and resell 1 at 25% cheaper. @MBS206, I am not sure if they do a Kluger one, here is their list but it might be there under a global model name: http://www.lsailt.com/product/android-interface?page=1 Keep in mind these full android replacements have basically all the bits a phone does (cpu, ram, storage, wifi, bluetooth, usb interfaces) other than a screen (it uses a host), thus the $800+ cost. Android Auto screen mirroring is MUCH cheaper as it's just a cut down shell, input mirroring and output mirroring BTW I also need that "screen off" feature, it is much harder to see wildlife even if a dash is reasonably dark. Both the Fuga and V37 have display off buttons for night use, they just come back on for a second or 3 if you interact with it, eg skip a song.
