Hi Guys,
Ive decided to go for a 17" setup for street and thus going to sell my street wheels as they are no longer needed.
Type: Rota Grid
Size: 18x9.5 + 20 all round
Colour: Matte Black
Condition: 9/10. No marks other than where the wheel nuts held the wheel on. Gutter free!
Tyres: Good Year RS02's made in Japan. 255/35/18 with 5mm tread at the lowest point and 6mm at the highest. These tyres were only fitted in late December last year and probably a total of 2000km street driving.
Price: $1600. Postage can be arrange however this will be at the buyers expense.
Contact Jason on: 0423 324 906 / [email protected] / PM
https://www.sau.com.au/forums/topic/392294-rota-grid-matte-black/
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
