Group Buy, New R33 Front bar.
  • Replies 54
  • 4 weeks later...
Hi guys
Sorry for the huge delay in getting back to you, but my car will e out of the spray shop on Saturday.
It’s been about 7 weeks since I took it in, but $10,000 later it's almost all done. The car was all prepped; lead wiped and painted (doors and bonnet off, windows out etc) everything except the engine bay and boot have been painted.
Bad news is that the front bar isn’t ready to go on yet, as it required some modifications to my intercooler piping and the relocation of the auto-trans oil cooler, then I'll send it back and get the bar painted. I have also ordered side skirts from OS, which should be here soon and then both the skirts and front bar will be painted.
Pics will be up as soon as possible, the first set will be with the bar mounted but not painted, then the painted bar soon after that.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
