nah dont know specs, its a T04E, is on an HKS manifold with HKS ex gate so is pretty big. its laggy but not too bad. it starts making boost around 2500 but thats like 01-0.2 bar but gets up to my 08.bar at around 4000rpm......
are you running a metal head gasket or forged pistons to take it to 18psi? i know their efficiency range is around 18-22psi but i cant take mine that far with stock injectors and internals....
I will run RX7 injectors, internals are supposed to be good for 250rwkw, i would likr to get 230rwkw and will run up to 18psi for the steet. Mine is a TO4e as well, its the smallest fo the T04's they make and is not that big compared to the others.
Once I have everythink runnikng i will probably get another engine built a bit stronger depending on how it runs. Metal head gaskets are not required as much on RB20's due to their lower compression and it it is tuned right with no detonation it should be fine, hopefully.
217KW SPECS
FMIC
3.5" EXHAUST FROM TURBO
VG30 TURBO
1 BAR BOOST
S-AFC
BOSCH 910 FUEL PUMP
HKS CAM GEARS
ADVANCED IGN TIMING
HIGH OCTANE FUEL (70% ULTIMATE + 30% TOLUENE)
DCS HEAVY DUTY SINGLE PLATE
206KW SPECS
FMIC
VG30 TURBO
1 BAR BOOST
S-AFC
BOSCH 910 FUEL PUMP
Don't forget that the clutch makes a big difference as you have to be able to transfer the power to the wheels. We drove my mates car on the road and the clutch seemed OK but when we dynoed it it only made 213rwkw then we replaced the clutch and now it makes 231rwkw, a similar thing happened to me now my car feels a lot quicker as all my power is getting to the wheels.
I will post the power figure with the cam gears and normal Ultimate fuel once I have it de-tuned for daily use....still have a bit of the good fuel in the tank so I want to use it up :)
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
