Hey guys,
I'm currently looking for some new wheels for my 2001 V35 Sedan, I have read that the offsets to fit it are as such - 8.5 + 30 front (around this) and 9.5 + 35-40 for the rear, I was wondering how far out of these i can go because these offsets limit my options hugely.
Cheers for your help.
https://www.sau.com.au/forums/topic/393009-new-wheels-help-please/
Do a search through the M35 stagea section- I believe that sedans and M35s are about the same offset from factory/wheel arch measurements.
I'm running 8.5 +22 with nil issues- have seen 9.5 +20
http://www.skylinesaustralia.com/forums/topic/392727-avant-garde-m310-wheels-and-kumho-tyres/
You don't have to run square like we do, because of AWD. So you could go staggered.
You can go as crazy as you want- just have to get appropriate levels of low, and camber to suit. All depends on how low the car is.
click on my signature below if you want examples of wheels and offsets I have used before. One thing to remember if you are lowered and I assume you are, then there are slightly more options available to you. The lower you go, the smaller the offset you can run on your sedan. Please note, sedan and coupe offsets are completely different so don't even start comparing with coupes.
Secondly, The example above from G35 driver is probably one of the many extreme examples (slammed, rolled guards, stretched rubber and excessive camber).
I am currently running 8.5 +25 fronts and 9.5 +30 rears mildly lowered approx 30mm on Z suspension. The fronts are perfect while the rears are sticking out the guards by approx 5-10mm due to running 275s. If I lower it a bit more and run 255s it would tuck in nicely.
Below chart should assist you. It is assuming you are riding on stock suspension, so if you are lowered you can push the maximums out a bit further towards the guard but more importantly if you are going with wider wheels and the wrong offset, you may also start hitting your struts.
93661d1217440321-will-19x8-5-22-offset-fit-front-g35-sedan-sedan_wheel_fitment_chart.jpg
To be honest I don't know if shes lowered because i haven't checked (do you know stock height?), and thank you so much this chart helps alot hopefully ill figure this out tonight so i can get them on the way (i need new tyres and i want my new rims first)
if you have a look at the outside fender line (front & rear) it should give you a good idea of how they will be within the guards.
mine are actually +33 and + 38 but with the right setup and use of adjustable arms, anything really should fit.
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
