Hey everyone, just selling parts off my RB26 that were removed for upgraded ones. Everything is located in brisbane Qld but will post.
6 x 700cc power enterprise top feed 11mm same as sard injectors just in a different box. Only done a couple of runs on the dyno before they were replaced with larger id1000's. Paid $900 for these, sell for $750 ono including postage.
Apexi power intake kit, comes with 2 brand new filters $275 ono including postage.
6 x Stock RB26 injectors $250 ono including postage.
RB26 resistor pack with plug $125 ono including postage
R32 RB26 ecu, missing 1 mounting bracket. $100 ono including postage
R32 RB26 fuel rail $25 ono
https://www.sau.com.au/forums/topic/393031-rb26-parts/
  • 3 weeks later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
