so they put the worst tyres on my car for the RWC when I bought it. Not too bad in the dry but downright dangerous in the wet.
it currently has 215/55/17 which I think is the standard size.
I am thinking about 225/45/17 on the front and 235/45/17 on the rear. Anyone running a staggered setup like this? any change in handling?
Edited by reverseworm
https://www.sau.com.au/forums/topic/393113-tyre-advice/
Stagged setup is fine.
What size are your rims?
i ran 245/285 and it was fantastic !
i would do 225/40/17 and 245/40/17
45 is massive profile !
I got 30 now and far too small. 35/40 is best i think.
https://www.sau.com.au/forums/topic/393113-tyre-advice/#findComment-6253111
You can't go choosing what profile you want to run just for the heck of it. There is a reason why a 17" wheel runs a 55 profile and an 18" 45 profile etc. its to maintain your overall diameter and ensure's your speedo still maintains accuracy.
Use this calculator to work out what you should be using. 215/55/17 is the correct base line OD you can use in the calculator.
http://www.1010tires.com/tiresizecalculator.asp
Also, if you are running the factory 17s, no point going stagger widths.
These tire profiles you quoted 225/40/17 and 245/40/17 are wrong and definately illegal if you are in QLD.
https://www.sau.com.au/forums/topic/393113-tyre-advice/#findComment-6253149
http://www.1010tires...ecalculator.asp
I understand that the rims are all the same 7.5 inches all round, but given it is a rear wheel drive isnt there an advantage having bigger rubber at the back?
https://www.sau.com.au/forums/topic/393113-tyre-advice/#findComment-6253178
Advantages only really noticeable if you are running wider rims on the rears like 9, 9.5 or 10" which will allow you to run anywhere from 265 to 285s.
In your case you are better off running a square setup and 245/50 all round or invest in a new tire and wheel package in 18s and try and get them in 9" rears at least.
Thats my opinion anyway but you are more than happy to run staggered, i'm just saying don't waste too much rubber on a 7.5" wheel.
https://www.sau.com.au/forums/topic/393113-tyre-advice/#findComment-6253244
Cool thanks for that.
I guess I also love the staggered look.
I have found Dunlop DZ101's 225 and 235 for $157 a corner.
Dont you think 235 might be a bit too wide for fronts? I could get the same deal for 235 all round.
https://www.sau.com.au/forums/topic/393113-tyre-advice/#findComment-6253270
yup 235/50 are fine too for front and rear..not too wide at all.
If looks are what you are after in a staggered setup, you will probably be quite disappointed because there is not much difference between a 225 and 235.
Edited by n15m0
https://www.sau.com.au/forums/topic/393113-tyre-advice/#findComment-6253286
by going 235/45 you have effectively decreased your overall diameter by approx 25mm to factory. In QLD the legal limit is 15mm, not to mention your speedo will also be out and aesthetically, the gap between your guards and wheels will also increase giving you the 4WD look if you are on factory suspension.
https://www.sau.com.au/forums/topic/393113-tyre-advice/#findComment-6253314
It was raining this morning and I came around a corner I have driven plenty of times before. I wasn't going quick but the back stepped out and caught me completely by surpirse. Before I knew it I was sliding sideways into oncoming traffic.
That was just too close for comfort so at lunchtime I went down and bought new tyres.
I went for Nexen N6000 235/45/17 all round for $130 a corner. They had some 50 series Kuhmo's but they were over $200 each.
In terms of looks, you can't really tell the overall diameter is slightly less - it doesn't look wierd at all. And i checked the speedo against the GPS and it is out by about 4-5 kms at 60kph.
Tyres feel so much better already. Thanks for your advice guys.
https://www.sau.com.au/forums/topic/393113-tyre-advice/#findComment-6254724
I thought you had to be no different than 30%...
where did you read 15mm?
https://www.sau.com.au/forums/topic/393113-tyre-advice/#findComment-6254994
http://www.tmr.qld.gov.au/~/media/c792a0c9-92b1-43ee-933b-7bdd8b20842f/pdf_modification_motor_vehicles2.pdf
Page 18. its 15 mm and usually works out to be approx 3% variance allowed...not 30%!
The rim diameter may be varied from the standard size but the overall diameter of the tyre must not vary by more than +15mm or -26mm.
These limits have been set for a number of reasons. Varying the overall diameter of tyres affects ground clearance, centre of gravity, brake effectiveness, steering geometry, performance and speedometer accuracy.
https://www.sau.com.au/forums/topic/393113-tyre-advice/#findComment-6255008
I've got the N6000 on my daily, a 5.7 litre commonwhore with plenty of torque and to be honest they're pretty reliable in the wet. They've not lost traction yet........................touch wood
https://www.sau.com.au/forums/topic/393113-tyre-advice/#findComment-6255132
If your car used to run the same sized tyre all round, and you run tyres with different circumferences front to rear then you can affect your traction / stability control and ABS (since they all rely on wheel rotation). Since that circumference is also not the same as stock, your speedo will also be out.
Staggering tyres is only useful if your car makes enough power to actually overwhelm the grip in the dry. In the wet, wide tyres is a negative to grip. Tyre compound and design will also make a bigger difference to grip and handling than the width. Buy a better tyre, not a wider tyre, if you want grip.
Unless you run a massively different tyre size, the aesthetics aren't even noticeable.
https://www.sau.com.au/forums/topic/393113-tyre-advice/#findComment-6255453
Just been reading a long thread on tyres, is wider better..
Depends how your car is set up, etc but summary i got was, yes wider is better but only is has the correct suspension set up correctly.
http://www.eng-tips.....cfm?qid=102250
Edited by R6n350GT
https://www.sau.com.au/forums/topic/393113-tyre-advice/#findComment-6255980
Think about what you said, which is "yes but only if X, Y, Z". In other words, the answer to "is wider better" is actually "maybe".
In practical terms, if you want to improve grip then changing the tyre compound and construction is far more noticeable, and with far less caveats, than changing the width.
https://www.sau.com.au/forums/topic/393113-tyre-advice/#findComment-6258054
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
