Hi guys.
Im selling my V35 skyline wheels, including Austyres tyres(215/45). All of those 4 tyres only have done about 500kms.
It was on my maxima A32 before. Sold my car, and not needing it anymore.
5x114.5 PCD
17 x 7.5 + 45 Offset (not sure if this correct, got it from net).
post-92145-0-74226600-1330577323_thumb.jpgpost-92145-0-56058700-1330577370_thumb.jpgpost-92145-0-88743900-1330577413_thumb.jpgpost-92145-0-43321200-1330577432_thumb.jpg
Price: $450 ono.
Just text me: 0431893864
https://www.sau.com.au/forums/topic/393427-wtsv35-wheelstyres/
Selling my Alpine (CDE-104BTi) as well. All working perfectly,included wiring hardness for nissan. The wire that connectd to iphone@ipod is not original.
More in depth info:
General Features:
Built-in Parrot Bluetooth Module
Front USB Connection
Full Speed Connection
Front Aux Input
Quick Search
SWRC Ready
Full speed AUX input
Rotary Encoder
Included BT Microphone
Display
1 Line LCD Display
White pixels
Bluetooth
Built-in Parrot BT Module
BT Version 2.0
Updatable for Future phone models
Outputs
Amp: 4 x 50W Max
2 PreOut (2v)
Power Antenna
Remote on Signal
Audio
MP3/WMA Playback
AAC Playback
HPF
Treble Center Freq. Con.
Bass Center Freq. Con.
Subwoofer Level Control
Price - $200 ono
Edited by ikhwan7
  • 1 month later...
Price drop to $400
And im also selling:
1) Hks muffler. Im not sure what Hks is that because it came with the car (R33). It have inlet of 3" then 3.5" pipe to muffler. The tip i reckon its 4.5". Price : $100
2) R33 rear strut brace. Price : $80
Edited by ikhwan7
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
