I finally have some stuffs for sale.
All items are located in Brisbane Southside. Pickup preferred but postage might be available :/
All items are negotiable. Except the cat.
1. Autotecnica wooden and chrome steering wheel. Comes with boss kit. Steering wheel was attached to a R32 but not anymore. $200
2. 3A Racing 3.5 inch pod filter. Good condition never used. $20
3. RB20 timing belt cover. Comes in blue (blue is the new black) $50
4. ASI performance radiator. Brand new never been used. Even comes with its own box. I can tell you what it doesn't fit (R33 GTST, R32GTST, R31, Passage) No idea what it actually fits but it looks like it would fit a R32 GTR. Not sure. Your guess is as good as mine. $150
5. Stray cat. Possibly 4 years old. Answers to the name of OI! Hey you! Stop carping on my rug! and Get out of it ya flea bag! $0.78c
* Cat may or may not be available on the day.
*All items come with a driveway gaurantee. Once they are off the driveway there is no guarantee.
Edited by skins
https://www.sau.com.au/forums/topic/393599-the-ive-got-stuff-for-sale/
6. Skyline rear facia from a series 2. Doesn't light up (1.5 does that) Comes in Blue (blue is the new black) Will make your R33 look cool $10
7. K&N filter. With plate that allows you to screw it to something. $25
*Screws are optional. Cannot gaurantee it will stay screwed to object.
8. Various intercooler piping. $20 The piping was originally from my epic high mount setup.
9. R33 bonnet latch. $10
*Doesn't come with bonnet
10. ? O_O Umm a black metal thing $5
*Black metal thing trademark of skins corp.
11. Standard intake piping for all your standard setup goodness. $30
12. Radiator hose $1 If you buy the cat you can have this for free!
13. Stainless steel 4 inch top mount turbo dump pipe. No cracks. Isn't bent / warped. Replaced with low mount setup. $150
14. Stainless steel top mount manifold. No cracks isn't warped / bent. Replaced with standard manifold. $250
*See epic top mount setup comment.,
15. Standard radiator for a R33. Comes complete with scratches, dints and no cap. Radiator works fine. Doesn't look flash though. Cap was faulty. $10
16. PWR Crossflow intercooler. Is like the force has a dark side and a light side. 2.5 inch pipe. Comes with optional extras (bolts etc) $250
*Ability to bring unity to the force untested.
17. 6 standard R33 coilpacks. $100
18. Various pipe clamps, a oil breather filter, intercooler piping and a twisted bit of pipe. $1
19. R33 standard BOV. All the cool kids have them. You know you want it. $30
  • 3 weeks later...
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • I guess one thing that might be wrong is the manifold pressure.  It is a constant -5.9 and never moves even under 100% throttle and load.  I would expect it to atleast go to 0 correct?  It's doing this with the OEM MAP as well as the ECU vacuum sensor. When trying to tune the base map under load the crosshairs only climb vertically with RPM, but always in the -5.9 column.
    • AHHHH gotchaa, I'll do that once I am home again. I tried doing the harness with the multimeter but it seems the car needed a jump, there was no power when it was in the "ON" position. Not sure if I should use car battery jump starter or if its because the stuff that has been disconnect the car just does send power.
    • As far as I can tell I have everything properly set in the Haltech software for engine size, injector data, all sensors seem to be reporting proper numbers.  If I change any injector details it doesnt run right.    Changing the base map is having the biggest change in response, im not sure how people are saying it doesnt really matter.  I'm guessing under normal conditions the ECU is able to self adjust and keep everything smooth.   Right now my best performance is happening by lowering the base map just enough to where the ECU us doing short term cut of about 45% to reach the target Lambda of 14.7.  That way when I start putting load on it still has high enough fuel map to not be so lean.  After 2500 rpm I raised the base map to what would be really rich at no load, but still helps with the lean spots on load.  I figure I don't have much reason to be above 2500rpm with no load.  When watching other videos it seems their target is reached much faster than mine.  Mine takes forever to adjust and reach the target. My next few days will be spent making sure timing is good, it was running fine before doing the ECU and DBW swap, but want to verify.  I'll also probably swap in the new injectors I bought as well as a walbro 255 pump.
