I read a thread from a few months ago about installing your GT-SSs, but I cannot find any info after the installation. Were they installed? If so, could you give me a link to what you think of them.
I just bought a D- Jetro with all the trimmings, now I am trying to decide if I want to go with GT-SS, 2510, or the 2530s.
I would like a quicker power band than stock, so I was thinking of going to a 9:1 with the GT-SS. I hate lag.
Thanks for any info you could give me.
https://www.sau.com.au/forums/topic/39391-merli-gt-ss/
To me when it comes down to who is the fastest in the 1/4, its who has the deepest pockets. My pockets are kind of shallow, so when I take a hit off of the "Go Fast Crack Pipe" a have to look at it a little differently. I want power for a street car, power that will be there without having to rev it to the moon.
1st thing is increase comp, that has and always will be the easiest way to increase power, of course you have to look at the problems of detonation, but if you are only boosting to 1.1-1.2 and using a higher octane fuel, with a good tune. I see no issue.
Second is get a turbo that suits your engine. The 2.6 is a fairly small engine, yes it can rev very high, but that induces other issues of longevity. I really cannot see me revving past 7500, ever. Any more than that you are running a risk of something letting go.
I know the 2530 has been a proven turbo for the RB26, but I think it might push too much volume for the application that I am think about, plus the from the limited info that I have been able to read about the GT-SS will spool a little faster, plus with the slight increase of compression it should be at full spool pretty early in the rpm band.
https://www.sau.com.au/forums/topic/39391-merli-gt-ss/#findComment-800632
I have encountered more setbacks than I care to recount.
Starting with an ever-growing modlist, which in turn leads to buying the new parts, which in turn leads to unreliable sources, or unavailable parts.
I should have rods and pistons by mid-May, when the car is going in for the work...
This is dragging on way too long and it's frustrating the hell out of me :(
Sorry I can't show you any dyno sheets just yet :)
https://www.sau.com.au/forums/topic/39391-merli-gt-ss/#findComment-801659
This is dragging on way too long and it's frustrating the hell out of me :P
Sorry to hear about your set backs.
I might just be the same boat as you here in a few months. If we start bailing water now, we just might make it:)
I hope to have mine up and running before the summer is over. I'll post my results for you guys.
https://www.sau.com.au/forums/topic/39391-merli-gt-ss/#findComment-802373
This is dragging on way too long and it's frustrating the hell out of me :D
Sorry I can't show you any dyno sheets just yet :rofl:
For anyone modifying a car (to *your* specs as opposed to what your workshop can get their hands on) - this behaviour is fairly normal. (sorry Merli) But I just wanted to point out to everyone the 'cons' of modifying your car.
One thing leads to another hey mate :)
https://www.sau.com.au/forums/topic/39391-merli-gt-ss/#findComment-820710
exactly... i think if you are building a specific engine it's a good idea to buy a second engine and build that up so that you can still drive your car. Then once the engine build is finished you can pull out your current working engine and fit the new one. Then you just sell your complete engine to get your money back on the initial purchase of the one you just built up!
https://www.sau.com.au/forums/topic/39391-merli-gt-ss/#findComment-820753
One thing leads to another hey mate :rofl:
No need to be sorry, you're absolutely right... But that doesn't make it any less frustrating!! :D
re: second engine, once I have all the parts ready to go and to give to the engine builder, it shouldn't take more than 2-3 weeks for them to do the rebuild. All they have to do is a full strip and rebuild from the ground up of an engine (but with all new goodies :)) so it shouldn't take too long. Builds only stretch on and on when you order parts and wait for them to come during the actual build.
https://www.sau.com.au/forums/topic/39391-merli-gt-ss/#findComment-820945
  • 1 month later...
Car goes in on Saturday for the build :)
And yes, GT-SS turbos are straight bolt-ons... I'm only building the engine for reliability for circuit racing, not to hold the power... Stock internals should be fine.
I should have results for you within the month :D:) :)
https://www.sau.com.au/forums/topic/39391-merli-gt-ss/#findComment-899794
Due to the nature of the automotive industry, and the backstabbing that goes on from workshop to workshop, I won't divulge that publically, in case I want to take my car to other workshops in the future to get some work done.
https://www.sau.com.au/forums/topic/39391-merli-gt-ss/#findComment-899859
So your not doing forgies now?
I'm doing everything shy of a stroker kit.
I was just saying that what I'm doing isn't necessary, and won't add any power... GT-SS turbos can be used on a stock engine just fine.
https://www.sau.com.au/forums/topic/39391-merli-gt-ss/#findComment-899860
Your doing it because you want to run NOS right?
Yes that, and I want the reliability of forged internals for the circuit racing I will be doing...
I'm also a firm believer of "doing it right the first time" :D
https://www.sau.com.au/forums/topic/39391-merli-gt-ss/#findComment-899913
    • Johnny is sad now... Because you didn't get Bosch Motorsport ABS.
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
