Hi all
I am new to turbo cars and mine is 3 days away, It has a turbo timer in it already and i was wondering how you go about stopping for fuel. I cant imagine everybody waiting at the pump for 5 mins before they turn the motor off, But then i cant imagine everybody pumping fuel in while the motors still running.
I know this must sound quite stupid but any help would be much appricated.
Lee
https://www.sau.com.au/forums/topic/3940-turbo-timers/
Yo Lee,
3/4's of the time, the TT isn't neccassary. Basically, I am on my 4th Turbo car and only 2 have had TT's because i dont think they are needed (in fact - i am selling an HKS unit atm).
The reason for TT's is to keep supplying your turbo with oil when its cooling down... if you just take it easy for the last 5 - 10mins of your drive (ie, hardly coming on boost) then you wont need to use the TT and you can turn the car off normally.
Hope this helps - otherwise throw another q at me - i am hella bored at work. :)
https://www.sau.com.au/forums/topic/3940-turbo-timers/#findComment-63976
If you thrash the car on high boost then switch the engine off the turbo is still red hot. The oil sitting in the turbo is heated beyond it's 'safe' range and it's properties may change. Then as the turbo cools from red hot to ambient the impurities in the oil in the turbo may solidify or condensation may build up at that point. Either way it's best to let the oil flow thru and cool the turbo slowly. That's my understanding...not very deep or technical I know! :)
https://www.sau.com.au/forums/topic/3940-turbo-timers/#findComment-63982
This makes me wanna take off my turbo timer...
what happens was coz I got an alarm system which will unlock my doors when I turn engine off & remove the key. If turbo timer is on countdown n engine is running, if I remove the key, the alarm won't detect it. If I press "arm" button, my system will go to valet mode, which will disable auto-arming feature for the purpose of valet parking at hotels. I can't even use my remote door unlock/lock coz pressing arm/disarm only goes from valet mode on/off. If I lock the door using the key and walk off the car... when my turbo timer finish its job, it will turn off the engine, and guess what the result is... my car will be unlocked.... anyone can just open the door, grab anything from the car and walk away maybe even with the car.......
And I've got the apexi pen style turbo timer.... :)
https://www.sau.com.au/forums/topic/3940-turbo-timers/#findComment-64333
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
