Parting out my R33 series 2...also selling my SR20DE, Located in Wollongong [NSW]
can post small parts :)
Have most r33 s2 interior plastics, let me know what you want
r33 s2 floor mats - $70
BMF44 brake master cylinder - $50
r33 s2 fuel tank - $70
r33 roof lining - $20
r33 kr4 silver fuel lid -$20
r33 gtst front 5 stud hubs w/ knuckles and brake lines, come with Whiteline adjustable front camber kit KCA348, RHS comes with LCA - $80 each
damaged series 2 front bar (KR4 silver) - $30
Whiteline adjustable rear camber kit KCA347 in suspension arms- $100
Right hand side front quarter (KR4 silver) perfect condition - $70
r33 kr4 silver driver's door - $80
1 x Right hand side nismo clear indicator - $20
hicas lock bar - $50
r33 gtst sidemount intercooler - $20
r33 gtst climate control unit - $30
r33 gtst interior door trims - $40 each
post-60012-0-24483700-1331192216_thumb.jpg post-60012-0-90658400-1331192233_thumb.jpg
r33 kr4 silver mirrors - $20 each
r33 rear view mirror - $10
SR20DE engine - done 114,xxx kms, with automatic gearbox/ gearbox x member, auto radiator and ecu... $550
r33 gtst GT side badges - $30
turbo timer - $30
apexi pod filter - $40 [someone stepped on it so it's a bit funny looking... still filters air like a boss though :D]
r33 gtst manual brake and clutch pedal (to suit manual conversion) - $50
r33 gtst clutch master cylinder - $40
r33 s2 fog lights with carbon fibre RHS - $50
r33 s2 "SKYLINE" rear garnish - $30
r33 s2 kr4 silver rear spoiler - $40
r33 RHS kr4 silver oem side skirt - $40
r33 turbo heatshield - $10
r33 exhaust manifold w/ heat shield - $30
r33 sun visors - $20
r33 s2 rear seats - $50
Genuine nissan r33 rear hicas ball joints 55154-OP800 - $80 for both [bRAND NEW]
r33 indicator / wiper switches - $30
r33 LHS kr4 silver rear light - $20
r33 turbo intake pipe modified with stainless steel piping - $35
Probably missed some stuff so just send me a pm if you want anything I haven't listed :)
Edited by Luke_GTS-T
do you have the other side skirt
No sorry only the one listed.
25 gearbox?
Gearbox is not for sale sorry.
r33 radiator sold
r33 floor mats sold
  • 2 months later...
  • 1 month later...
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
