I went ahead with the Type R front bar from Viva Garage.. And im pretty happy with how it came up so far.. I have had the bar pre fitted befor painting and have attached some photos..
The only problem is the bonnet lip does not sit flush onto my Z-tune carbon bonnet so Im not sure how im going to make it fit.. Still working on it.
And also it doesnt quite fit flush with the bottom of the headlight on the drivers side. It sits in about 10mm but the other side is ok. As u can see from the angle of the first photo.. But is really only noticeable from the right angle.
Will post some more photos when 100% complete. This is also the first time iv posted photos so not sure if this is the right way hahaha
Edited by R34GT4DOOR
  • Replies 54
oh f**k yeah, that looks sweet as
you need a bonnet lip of some sort
http://www.skylinesaustralia.com/forums/topic/394256-r34-gtt-front-bar-mole-nismo-carbon-gearknob/page__p__6268500__hl__aggroman__fromsearch__1#entry6268500
I just got my shit painted too, I'll upload some photos if you wanna see
It probably wont work with a lip because that bonnet wasn't designed to be used with a bonnet lip (top mole), those are just for when you use a gtr bonnet and a gtt front bar, the gtt front bars are chopped flat where it meets the bonnet where the gtr front bars have that extra 'lip' at the top as the gtr bonnets don't curve downward at the front.
If that makes any sense (makes sense in my head, maybe not in words though.)
Oh yeah, i know what you are talking about, so i assume you suggested it more to mask the fact that the bonnet doesn't sit flush with the bumper rather than as a fix per say lol.
I actually considered getting a carbon one, but i don't know, i wasn't 100% sold on the look
Haha yeah that made perfect sense but I don't mean the top mole that's used with GTR bonnet and gtt bumper. I meant the bonnet lips that attach to the front of the gtt bonnet, like the one I use to have
You mean like the one i have? Will it work with that front bar -
Yes I think it makes sense.. It's a bit confusing.. The bar came with a bonnet lip but I'm assuming it's made to fit a standard gtt bonnet.. Maybe the z tune carbon one is a little difference shaped at the front.. I'm not sure
Yeah I'm pretty sure that's the same lip that the bar came with.. It just doesn't quite fit right.. I suppose ya can't expect much when your only paying that price.. Il work somethin out..
Mine isn't a perfect fit... But close enough :thumbsup: You cant notice unless you are up close to the bonnet.....
Hey guys,
I'm also interested in buying this front bar from viva, however I'm not too sold on the bonnet lip from the photo's i see from the first page of this thread lol.
I have a black gtt, so hoping it would look good with this front bar. Shinobi, when you said to shave off some of the pillar things to make it line up with the bonnet, how would go about doing that? Just for future reference if i end up going with this bar lol.
Thanks!
Heres another photo,
Still has to be sprayed yet but first im off to melb for a tune ect..
Looks good from the front, how does it line up with your side skirts etc from the side?
<p>
</p>
<p> </p>
<p> </p>
<p> </p>
<p>It sits heaps lower than the rest of the car.. It also sticks out more..  I would recommend getting somethin that flares out abit like the impul skirts to match up better but i bought the Z-tune style ones a while back and am outta cash to change my mind about it -.-</p>
<p> </p>
<div>
</div>
<div> </div>
<div> </div>
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
