Hey,
I have a selection of various car bits and pieces.
A31
Cefiro Manual ECU (23710-73L00). Remapped by Jeff from the Speed Lab. $300
Tuned for VG30 turbo @ 13psi, Walbro fuel pump, FMIC, and 3" turbo back exhaust. Stock AFM and injectors. 175kw @ rw.
Random
Work Wheels Stickers. Genuine. Came with my set Work Meisters. Blue. Set of 4. $30
Q45 Infiniti Ignitor (22020-60U00). $50
SCA Car Stands. Pin type. 1200kg. $25
Stanfred Car Ramps. 750kg. $50
Pro Lift Scissor Jack. 1000kg. Works perfectly. $30
MSD 6 Series Vibration Mounts #8823. $10
All parts located in Adelaide, Enfield 5085.
Extra for postage interstate.
PM me or message me on 0434 030 114.
Cheers
post-38219-0-27845500-1332132268_thumb.jpgpost-38219-0-41363200-1332132277_thumb.jpgpost-38219-0-28914600-1332132342_thumb.jpg
post-38219-0-10374400-1332132326_thumb.jpgpost-38219-0-55399900-1332132334_thumb.jpgpost-38219-0-96848500-1332132374_thumb.jpg
post-38219-0-90686200-1332132405_thumb.jpgpost-38219-0-63613900-1332132414_thumb.jpgpost-38219-0-73115300-1332132423_thumb.jpg
Edited by rayj
    • Hybrid sounds like a supercharger... It's half a turbo, with a belt to drive it! Oh wait, they're just called super chargers...
    • It's either an ignition failure or a fuel failure.
    • Before starting any work, we attempted to adjust the tune. However even after adjusting it to certain extremes like completely stopping fuel, it had no effect. What fixed it was removing the Nistune Board and installing the original EPROM instead. This immediately fixed the issue. Everything should have been fine with the Nistune Board installation, so I am unsure why it has caused a problem. The soldered connector is also properly soldered. This worked when I first got the 550cc injectors, before cleaning, but that may have been a coincidence.  We ended up not installing the fuel pump hanger (at least for now). So currently running stock injectors, stock fuel pump, stock fuel pump hanger – Well everything stock except the exhaust. Now I have around €1400 in Nistune, Injectors, and Hanger collecting dust for the time being, perhaps I'll install them in the future. For now I'll enjoy the car as is 😁 Thanks a lot for all your assistance, I really appreciate all the help you have given me.
    • The turbo can’t be the issue. They’re proven to make much much power than you’re making. There is something in the setup that isn’t correct. - has the exhaust got any silly step downs? - what exhaust manifold?
    • Ok, just the way you wrote it made it look like you had the stagger the wrong way around
