2001 Nissan Skyline V35 300GT
V6 3.0L
Auto
69000kms
RWC
REGO till 14 July 2012
I went to look at a few other 300GT & 350GT before purchased the car, this was the best one (body paint, interior, exterior, engine, transmission $ suspension condition wide etc) at the time. Fresh imported in July 2011, I am the second owner.
Had a major service done by Nissan Renault straight away the next day. Never had a single problem ever since. Car starts at every first time, ice cold air conditioner and heater works perfectly, as well as all the other electronics.
This 300GT engine has direct fuel injection system which provides almost the same horse power as a 350GT does, but still the fuel consumption is better than a 350GT, I am constantly getting almost 500kms out of one tank of petrol.
Straight body, no rust, no accident history, all genuine factory panels, shiny as new factory full pearl white colour, as you can see the bottom of the bodykit matches the body's colour. Rare black leather interior is in tip-top condition, comes with full set of factory floor mats and pop-up information display unit, displays trips info, fuel consumption, left range, compass, altitude and more.
The list below are some quality items that added to the car to make driving more joyful.
- infiniti badge front chrome grille & steering wheel
- Double dins center console pane
- JVC 7" touch screen DVD/MP3/iPhone player, charging as well
- Reverse Camera displays on JVC headunit
- LED interior light
- Philips 5000K Xenon Headlight
- Clear side indicator
- Aero wipers
- Auto folding side mirrors
- Auto "look down" side mirror when reversing
- NGK Laser Platinum Spark Plugs
If you want a comfortable, fast, JDM and rare looking daily, this is definitely the one for you. It is also a great platform(same chassis as 350z) to turn into a sport sedan or VIP style sedan, loads of parts available.
$15000 without Rego or RWC
$16000 with Rego and RWC
Any test is welcome, please feel free to contact me at any time.
XXXXXXXXXXXXXX
Edited by Nightcrawler
https://www.sau.com.au/forums/topic/395609-infiniti-skyline-v35-300gt/
  • 5 months later...
Guest
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
