Hello SAU,
1994 R32 GTR
Engine, just under 15,000 km put on since rebuild (Weekender)
ENGINE
- R33 Block, all internals have been changed or modified
- Crank
- Forge Pistons
- STD Rods
- ACL Race Bearings
- Head Studs
- N1 water and oil pumps
- GT 2860-5 turbos
- HKS dump pipes and front pipes
- Very hi flowing cat
- HKS Hi Power Silent Exhaust
HEADWORK
- Custom grind camshafts (264/264 11.0mm Lift)
- Mine's adjustable cam gears
- Valves , springs, lifters and all to suit camshaft profile
- Extensive porting on intake and exhaust sides
EFI
- Sard intank Fuel pump
- SARD Fuel Rail + Fuel Pressure Regulator
- SARD 700cc Fuel Injectors
- Platinum PRO
INTAKE/COOLING
- 110mm thick intercooler
- HKS intercooler hard pipe kit
- Twin K&N Intake + Airbox
- Aluminium Radiator
- Oil Relocation Kit
DRIVETRAIN / SUSPENSION
- Reconditioned Gearbox
- front and rear LSD's
- 17x9 inch Volk Racing GTU (Tyres still have plenty of tread on them)
- BC Coilovers
- Reconditioned Front Driveshafts (Boots were ripped, installing them this weekend)
INTERIOR/EXTERIOR
- Haltech Platinum Pro now running on MAP Sensor
- HKS DB Chrono meter gauges, (boost, exhaust temp, water temp, oil pressure)
- Turbosmart e-boost street boost controller
- Clarion single DIN DVD Player, mp3 divx all that stuff
- Fusion and clarion speakers
- Trust Side skirts and Rear Pod
- Top Secret rear Diffuser
Car has ran an 11.4 @ 117mph 1.6 60ft when it was making 312kw (N1 Turbos) with the old Setup
Have not been back to the track since the new build. Car recently tuned at JEM (12/03/12) made 347kw atw @ 20PSI, 819.6 Ft LB of Torque.
PRICE: $24 000 ono
Contact: PM or 0404 059 305
https://www.sau.com.au/forums/topic/395643-eoi-1994-r32-gtr/
  • 1 month later...
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
