Hey guys,
Ive got a complete R33 manual Series 1 gtst. coupe
The shell has currently been taken back to bare metal for a respray. can sell the shell as a whole or keen to wreck.
Let me know what you need, as it is a complete car.
Also have a complete drivers side door in silver (mint condition)
Located brisbane southside.
0419 743 272
i need wheels!!! are the tyres legal?
Hey mate,
unfortunately all I have is a pair of fronts, a shitload of R33 stockos, and a set of R34 GTT wheels in flat black.
i only need 2 wheels preferably the same for the rear with preferably the same tyres on them and legal.
What just for skidders? don't care to mix and match(doesnt matter 16/17/18? i can see what I have got
how much for 34gtt wheels pm me
$200 bux for the R34 gtt wheels, they are in flat black and one has some gutter rash (big swipe,) just needs more flat black
hey mate are u selling gear box engine ect if so how much
pms sent.
Hey mate,
Box and engine are already sold. have spare bottom end are bare heads but thats are far as I go.
Oh yep, got a bare long with a 125,000 genuine kms on it, 155 psi across all six though she wouldn't part from me unless $1100 was swung my way.
how much would u want for both front brake calipers and rotors?
Pm me.
Hey mate
unfortunately not parting out brakes,
Going to be sold as a complete 5 stud conversion for $500
