Hello All,
I have a 1995 GTR V-spec for sale if anyone is interested. Details are:
Silver
3 1/2 Inch Full Exhaust
18" Mag Wheels
HKS Valve Controller
Turbo Timer
HKS Piping
External Oil Cooler
Air Conditioning
Power Steering
Power Windows
Power Mirrors
Brembo Brakes
ABS
Hicas
Active LSD
Asking price is $42600 ono
https://www.sau.com.au/forums/topic/39588-for-sale-1995-r33-gtr-v-spec/
Its done a low 30,000kms. I imported it and got my contact in Japan to locate a near new one which it is as you can see from the pics.
Thanks
god damn ! there da enelki rims that i had on my sky. until i had a accident and bent 2 rims- and they couldn't find a replacment
Hi There,
My name is Gavin and I am interested in your GTR. Could you inform me of the FULL details of the car please? ownership years? accident damage? reason for selling etc etc..
Are you neg on the price or shipping to another state?
Regards,
Gavin
Hello Gavin,
Full details of the car, well I imported it in about october 2003 from Japan, originally I wanted a series 8 RX7 but settled for the GTR. I am sellingit because although this is a great car I still want the series 8. Car is in excellent condition with no problems or acident history. Only noticable thing is that one of the lights has dulled. The car hasonly been driven about 3000kms in Australia, most of which has been down to wollongong on the weekends. Apart from that the car is always garaged and is filled with BP Ultimate. Price is a little negotiable but not greatly and I dont mind shipping the car interstate. If there is anything I have forgotten please ask. Thanks
no havent replaced the front left headlight, and if I did I certainly wouldnt have replaced it with one that looks yellow........ I would have bought a nicer looking one....... Im sure it can be cleaned up to look clear again just not sure how......
Very nice GTR
Think the price may be a bit high .... Plus the import market is pretty poor at the moment. Its only worth what someones willing to pay for it.
Ummm, try polishing the headlight with something like cut & polish. Worked for me when I did mine
Cheers
Tom
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
