Definitely For Sale
The car is a 1999 - R34 GTR V Spec
Bought it about 24 months ago (give or take) with 48000km on the clock. Thatclock has since been replaced.
As a ball park figure, there would be between70-80,000km on the car all up.
I'm the third owner in Australia, car belongedto another forum member prior to myself.
The car is in great shape save for a fewissues that come with being 12 years old.
stone chips here and there, scratches where you'd expect to find scratches.
There's a small wear mark on the bolster of the drivers side seat and thediffuser lip has seen better days
And a match head sized spot of rust under thebrake light on the boot.
I'm Located near Parramatta
Email: [email protected]
Phone: 0408678265
Well, Ok then.
onto the details.
Engine:
Internals are stock standard with the following bolt ons:
Garrett GT2860R-7 Turbos
Apexi power FC with hand controller
HKS EBC and turbo timer
HKS Adjustable Cams
Split Fire coilpacks
Power enterprise 700cc injectors
Bosch 044 fuel pump
Apexi Pods
HKS hard pipe kit
apexi carbon cold air box
Mines carbon radiator shroud
X force split dumps
Impul Front pipe
Impul blast cat back
Gutted cat.
100mm inter cooler
Air oil Separator
Exedy Clutch
Brakes and Suspension, Tyres and wheels
HSD HR Coil overs - They get shit done
DBA 400 Slotted rotors
Project Mu carbon metal? rear pads
Endless CCA front pads
Standard GTR Wheels
Eagle F1 Symmetricals - 245/40/18 - More tread than you could ever possiblyneed (your results may differ)
In car there is:
Mongoose M80s immobiliser and alarm
320kmh nismo speedo
eclipse head unit with ipod controller (top ofthe range)
Boston acoustic front splits
Boston acoustic rear 3 ways
Clarion 2 channel amp
Alpine 4 channel amp
Pioneer 10 inch sub
Tuned by Croyden Racing developments toproduce 307 AWKW This car has been a pleasure to ownand drive, it's always been well looked after and needs a good home due to a pending move south of the border. Asking $50,000 - My loss, your gain
post-71498-0-75628200-1332856533_thumb.jpg post-71498-0-81492500-1332856546_thumb.jpg post-71498-0-91986500-1332856561_thumb.jpg
post-71498-0-96745700-1332856573_thumb.jpg post-71498-0-43103500-1332856587_thumb.jpg post-71498-0-35034100-1332856598_thumb.jpg
post-71498-0-01615100-1332856608_thumb.jpg post-71498-0-97660800-1332856620_thumb.jpg
https://www.sau.com.au/forums/topic/396156-r34-gtr-v-spec-1999/
Hi,
Please send me VIN number to run through fast.
Do you still have the original cluster?
Also, no 'Ext temp' or 'Int temp' readings on the MFD. Please confirm if this is a vspec GTR.
Thanks.
Still got the original cluster.
The exhaust and intake temp readings on the MFD: When the dumps were changed the exhaust temp sensors went too. After that the next time I activated diagnostic mode to calibrate the throttle reading the computer couldnt find an exhaust sensor so it removed those two 'vspec' options from the MFD.
Can I ask what silver this is? it will be on the build plate listed as a paint code.
There's a few silvers and it's difficult to tell from photos. (athlete silver? sparkling silver? etc..)
Sonic Silver KR4
from memory
Sonic Silver KR4
from memory
looks like it.
same colour as mine, people always comment on how good it looks too :)
very nice car in photos and the one time ive seen it, glws!
  • 1 month later...
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
