Hey guys got a really good condition pair of r32 gtr seats. Removing them to fit a fixed back.
Sms for pics as I don't have access to a PC at the moment.
After $500 for the pair.
Located in Mt Evelyn Victoria.
Cheers
Nic
0433 179 630
https://www.sau.com.au/forums/topic/396238-pair-of-r32-gtr-seats/
  • 3 weeks later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
