  • Replies 78
appologies 4 the hijak, it is related though...
I was down JMS way last night and there was a fair bit of action. there was some class out there last night. it was good to see some good action out there. ne1 else out there last night?
can't wait 4 the drift day!
as previously mentioned if it rains (which it will) it will COLD and WINDY as hell out there. Anyone who went a couple of times ago will testify to this. Instead I reckon we should have a late arvo cruise, then grab some dinner somewhere then head to my place for a piss-up with DVDs, 8-ball etc. Please post here or PM me if you are interested and I'll tell you when and where
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
