Hey all
Just joined up after a while of trawling these forums. Bought my stagea about a year ago.Figured Id say hello and post some pics.I dont think its anything special, no rare of unusal parts that im aware of.
Its a 97 RS4 , 25det auto, twin sunroof, privacy rear windows, lowered on 18's (which i hate), came with a stupidly big and loud drooony cat back exhaust. Its bog standard in the engine bay.Pretty sure the bodykit on it is a DAYZ edition ( can someone clarify)
Thus far I've fitted the tow bar and wheel spacers all round to fill the guards a little.Also purchased some Snowboard roof racks as it was bought to go to the snow ( 4wd, big boot). Also put some 6x9's in the rear doors as the factory ones had literally disintergrated. Previous owner put a headunit and some unknown 6.5"s up front with seperate tweeters.
Some previous owner pranged it, rear bumper has damage, front bumper and hood have been replaced and badly spray painted a similar silver. Right guard has a couple of dents.
/rant more pics
Lastly, I need some tech help.
Heater core is leaking as of yesterday. Was about to blame mum for buying fish from the grocery store when I noticed a nice puddle of green in passenger footwell. FML
Have read about it on the site. seems the skylines are easier to do, as behind the glove box, the skyline doesnt have the dash bar going across. So, on a stagea, do i have to pull the entire dash or is there another way??( Airbag business scares me, rather not mess with that stuff )
Also, the core itself, are the skyline ones interchangable, if so, which model do i need to look for??? I dont like my chances of finding someone wrecking a stagea who i can get a stagea specific one.
PLEASE HELP.
Thanks in advance.
https://www.sau.com.au/forums/topic/396393-another-rs4/
Heater cores are available new (no point in buying a second hand one that's just as old as yours) for not much money from your local radiator shop (Natrad). I thought it was possible to get at the heater core by removing the aircond fan and glovebox etc but maybe you are right in that its different to the skyline.
I have 17s on my RS4 (TE37) but I think R33GTR rims look good on Stageas...at least I prefer them to the R34GTR ones.
https://www.sau.com.au/forums/topic/396393-another-rs4/#findComment-6296451
  • 5 weeks later...
The R33 heater cores are Z32, you will need to check if it is the same but it probably is the same. The price of a heater core should be under $150 last time i checked (but it was a while ago).
You can join the hoses in the engine bay in the meantime to bypass the core while you are getting it out.
https://www.sau.com.au/forums/topic/396393-another-rs4/#findComment-6336128
  • 3 weeks later...
Heater core not fixed yet, but I'm told buy new wheels cures all ;)
R35 350 GT skyline wheels, 18x 8 +30 rims with 225/40 and 235/40 tread.
Have gone for a flush-ish look with +25mm spacers up front and +15 in the rear making it essentially 18x8 +5 front and + 15 rear.
In the photos the 25mm spacers are still in the back and the 15's up front, they were switched around.
Will try get a few better snaps when the stinkin rain pisses off.
Edited by troubleslab
https://www.sau.com.au/forums/topic/396393-another-rs4/#findComment-6357061
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
