i have been running wasted spark on a set of splitfires for about 5 years now. The coils will have NO issues in wasted.
turn logging on, and log it when it misses, you might be getting some bogus rpm signals, this is because the 360 optical sensor is really hard for the ecu to cope with especially in a modified engine, i found that cars with modded heads, springs and cams have more issues with this then stock head setups.
check the rpm signal, see if its stable, hold the rpm at one speed and then see if it goes up and goes down in the log, make a log when the car misses, is the rpm jumping over the rev limiter? or is it moving about strangly?
You may need to contact autronic, buy a trigger disk for nissan optical sensors and install it, I have done this to 3 cars in the last 2 months to fix the same issues, the issue is not haltech specific its the fault of the 360 slot hall setup.
the trigger disc should cost about $100 or so, i had to put one in my RB30DET after i changed the cams, before the cams i had no issues...
yeah did all the logging, not a single problem spotted, the miss counter shows a nice stable rpm.
anyway the problem was found in the end. would you believe it was something as simple as sparkplugs. I had 6 brand new NGK plugs in there and 3 of them proved to be faulty in such a way they wouldnt spark correctly, irrespective of what coils used.
not really the word i'd use for it... more like waste of f**king time... so much dyno time wasted chasing issues... guess it comes down to never assume that just because a spark plug is new that it will spark correctly
Can't say that I've ever come across an issue with spark plugs being bad out of the box. The majority of case I've seen is usually due to improper installation - not saying that's the issue here I've just never seen it myself and when you've changed thousands of plugs on high performance engines I would think that's a pretty good sample.
i havent come across it either. im a mechanic and have changed my fair share of plugs. these were brand new and out of the box failed to work. im not sure how but i chucked some 2nd handies in that had been sitting in a pile of crap. blew em off with an air gun and boom, car runs on 6 all the way thro the rpm range.
    • Hello, just just bought an 1999 enr34 with a stock rb25neo and I'm looking to upgrade the engine to 500whp I know some basic things but wondering if there are things I'll need to do to upgrade the stock block and all the bits and pieces to achieve this.
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 😅
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 🫠
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
