Hi
I'm looking at upgrading my injectors and fuel pump to match do you sell pumps and mayb fuel rails if so can u send me some prices?
  • Replies 191
Hi
Hi,
Sure thing mate, we can do the lot!
What vehicle is it, top feed injectors and rail? What sort of power are you looking at?
Let me know and I'll set you up.
Brendan
(VM)
Hey mate
R34 rb25det neo, looking to upgrade turbo as well want to be knocking on the door of 300
Hey!
Are you going to be running to feed injectors? Using an aftermarket fuel rail?
Turbo's we don't do as yet.
Let me know,
Brendan
(VM)
hey Brendan chasing some 1000's for my 34 neo with standard rail. not to fussed on brand. also do you sell e85 compatible fuel pumps? cheers
Yes and Yes :yes:
The EV14 BOSCH injectors are the most popular on the market today, come in 550cc, 725cc, 1000cc, 1150cc.
I can supply them with extensions to make them full size injectors and plug's.
The fuel pump is the Walbro E85 460LPH fuel pump, the only in-tank purpose built fuel pump on the market today, comes with all fittings and 2x strainers.
- Brendan
  • 4 weeks later...
More injectors coming soon >>
We are looking to increase our range of side feed injectors, for all those not looking to change their fuel rails to suit top-feed!
hey mate after fuel pump + 550cc injectors suit r34 gtt neo, pls pm me price and best payment method.
p.s standard rail and plugs. cheers.
Sent ur way!
Hey!
Let me know,
Brendan
(VM)
Sorry for the delay yeah aftermarket intake and rail not sure yet if 740's or 1000cc but around them.
Will need fuel pump as well.
Do you sell fuel pressure regs? I've had one for ages I got for nothing but needs a gauge.
Thanks
Thanks
No probs buddy
We have both 750cc and 1000cc injectors available, these are E85 compatible and very easy to tune.
I would go with either a 400LPH or 450LPH fuel pump - both Walbro.
We can set you up with a T/S gauge depends on the HP your going for...
Let me know,
Brendan
(VM)
How much for the 1000cc and a 4500lph r they external? Just so I can factor in an fittings and hoses, also I'm guessing a rewire too on higher voltage. HP 500 ish
Ok sure,
All 6x BOSCH 1000cc injectors with plugs and extensions to suit would be $660, the E85 unit is an in-tank pump and would be $220 with all fittings and strainers.
  • 4 weeks later...
Hey mate, was after a quote for 4x1000cc injectors for an SR20det and a fuel rail as well. Feel free to PM, cheers.
Sent through now
  • 1 month later...
Hi there,
I'm looking for a set of injectors and E85 fuel pump for an R32GTR making 363 awkw on 98 pump. Looking to make the step to E85. Any recommendations/pricing?
Thanks
Hi there,
Thanks
Hi mate!
I would go with the BOSCH 1000cc injectors, they are the only unit's which are purpose built for E85 and race fuels.
Price on a full set of 6x flow matched with extensions and plugs would be $660.
Cheers,
Brendan
(VM)
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
