Ok Guys here goes
I am looking at getting a GTR but my wife has told me that for me to get another toy then one or both of the current ones has to go.
So i thought there may be someone out there who is looking for a change who knows.
So here goes
Evo Price $16k or swap for a R32 GTR
Sti Price $25k or swap for a R33 GTR
Will swap for both for a R34 GTR
The Evo specs
Engine: 4G63
Exhaust: 3 inch stainless
Suspension: G4 coilovers
Wheels: 17in ozzy racing rims
Modifications:
T67-25G turbo,
stainless manifold,
4inch intake,
blitz air filter,
HKS cam gears,
turbo xs bov,
dry cell battery,
rebuilt gearbox,
3300lb custom npc clutch,
sard fuel pressure reg
walbro fuel pump,
Mines ECU,
eboost 2,
3inch mandrel bent stainless exhaust,
stainless double dump
MSD ignition system,
NX nitrous kit,
Carbon fibre NOS bottle,
NX spray bar on cooler,
front strut brace,
koyo 56mm alloy radiator,
silicone radiator hoses,
alloy catch can
EBC red front brake pad
EBC green rear brake pads
slotted rotors front & rear,
stainless braided lines,
10k hid kit, ,
factory sunroof
factory recaros
sparco drivers harness
carbon fibre floor panels
autometer gauges
just been re-registered
The specs for the Sti
genuine 2 door version 5 sti 1 of 400 brought in by subaru
the version 5 was the only 2 door subaru every sold new here and the very first of the sti series sold in Australia
206kw power output has only just been beaten in output by the lastest 2008 onwards sti's using the 2.5lt motor
and this one has been enhanced
and unlike later models this one cant be mistaken for a normal wrx with a big wing
has just been re-registered
EJ20 motor rebuilt with reciepts
aps stealth front mount intercooler
APS silicone IC hoses
VF24 ball bearing turbo running only 15psi
turbo xs hybrid BOV
Autronic SM4 plug and play computer
walbro 255 fuel pump
aps mandrel bent stainless exhaust
k&n filter
rebuilt radiator
22B bonnet vents
my02 sti wheels
6000k hid kit
This is legit, i own both cars outright and i also have a E series Clubsport as my family car and a VE company car
Both cars are toys and only driven when i feel like driving one of them.
Cheers for looking Troy
0417 362 048
Edited by evo201
https://www.sau.com.au/forums/topic/397209-modified-evo-sti/
The evo is legit
Power wise it makes 260awkw and is on full boost by 3500rpm (cam timing, and gearing make a huge difference on these)
car has run a best time of 11.4 with the NOS and runs 1.760ft times so it flies.
Nice STi mate, i used to own a 2-door myself. And mate they bloody fly! Km's mean F'all if the car has been maintained properly and esp with the engine has been rebuilt with forgies.. cant go wrong with a 2-door STi.
  • 3 weeks later...
  • 6 months later...
  • 1 month later...
Hey mate,
I just posted a thread on here about my little red type r dc2.
Would u be interested in it ? for the evo ?
u can have a look at some of the pics on the thread should be first one up there.
cheers
  • 2 months later...
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
