I'm currently half way through a tune with Morpowa (Modbury) as they used to do my mates track car, supposedly good with Nissans, will let you know if I'm happy after Tuesday.
I've heard that Jaustech (Holden Hill) is cheaper and also very good.
Thanks guys. I really am after a place south way. As it won't be getting a tune or anything just want them to look over it. See what they think of it etc. Make sure nothing is drastically wrong before I buy it etc
Manta Racing Services are very highly regarded
Theyre not way down south but might be worth the drive...
http://www.mantaracing.com.au/
-D
Personaly I wouldn't go to Souther Hi Tech Dyno as when I took my car there for a bad idle ect I asked them to go over all the intercooler pipes and they said it was all good and couldn't find any pipes off and tryed to sell me a Power FC for like $1500 and got the car towed to Morrie at Horsepower In A Box in the end to have a look and he knew what it was as soon as he started the car and I have used him ever since and recommend him to everyone as it's great/friendly service and he knows what he's doing and he also has a 2WD Dyno.
Nothing but Thumbs up for the boys at jaustech (anthony and peter great blokes and allways love a chat),they only have a 2wd dyno tho (last time i was there anyways)
Turbo tune tuned my mates r32gtr vspec2 when he got it imported,got coilovers from them and a gearbox rebuild and a new clutch. When i was there with him tho the guys seemed a bit uppity and not down to earth normal blokes. Not sure what tunes/services cost from other 4wd tuners but his initial service and dyno tune (all fluids changed etc) was 1700 and his car went from 167kw to 221kw atw, gearbox rebuild and new clutch was just under $4k i think and a set of bc racing coilovers fitted were $600, as i said not sure if these a good prices for gtr tunes/servicing but his car does go like the clappers,i dont think they put the right clutch in tho as it slips.
Heard good things about horsepower in a box and wilall but i couldnt comment on first hand use of these tuners.
Thanks guys, unfortunately Steve knight was to busy.
But on the plus side the Gtr is booked into racetech tomorrow. Fingers crossed it all checks out and I'll have it bought and paid for by the weekend!
I would have said to give Graham West Workshops a call as well. They have AWD dyno, and are pretty good. Slightly pricey but you get what you pay for I guess. I have used them in the past and have had really good dealings with them.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
