Hey - it was a sad day in the shed today... I changed the timing belt and tensioners on my R32 GTR and now I have some serious problems....
I would consider myself fairly experienced in the shed, i've built say 10 high performance L series Datto engines and have tinkered in the shed since I could walk. Changed quite a few timing belts over the years with no issues.
OK so this is how it went down:
1.) Pulled the old timing belt and tensioners off
2.) replaced the tensioners
3.) Fitted the belt (100% sure timing was ok - and it still is ok)
4.) Adjusted belt tension as per the book. Timing belt flex was basically the same as the old one.
5.) Tuned it over a few times by hand - tension all ok.
5.) Refitted everything required to run except upper cam pulley cover
6.) Fitted the CAS without the cover and started the engine - all ok.
7.) Ran it for a few mins and observed the belt - ran true and was all ok
8.) Fitted the covers etc etc etc
9.) Started it and it and after about 10 seconds it made a strange sound - like the a flange rubbing on the front pully or something.
10.) Killed it immediately (was standing at the engine so I guess it ran for a few seconds)
I stood there for a good ten mins thinking about what it could have been... anyhoo... I then noticed oil leaking from under the front pulley... I pulled the top cam cover off and noted that the new belt had partly disintegrated and there was oil everywhere.
I haven't pulled the bottom cover off yet so I don't know if if the oil is coming from the front main or the cam towers or what.
Has anyone got any ideas as to what might have gone wrong ? New tensioners look ok but can't tell if they are stuffed until I pull the radiator bottom covers etc etc. It almost looks like the belt was rubbing on something - the edge facing towards the engine...Then it shredded and the long sting bits wedged up hard again the oil seals and took them out...
Any ideas ? I'll grab a new belt / seals tomorrow - but I just don't want this to happen again... Thank god the belt didn't break.
Cheers,
Jeff
what brand of belt and tensioner?did u buy a full kit including seals?did u replace all seals?id be pulling both covers off and check for rubbing on the covers or anywhere else.also check all pulleys for any movement.one thing ive learnt over the years is do skimp on a timing belt kit.hope this helps good luck.
Cheers mate will do - everything is genuine Nissan stuff. Didn't replace the front main or cam seals as they were done about 30K ago... but i'll be doing them now I guess.....oh well live and learn - i'll post back with what caused it when I pull the bottom cover off tomorrow....
Update - Pulled the bottom cover off. The only thing I could see was they idler puller tensioner spring was not sitting on the locating dowel. But it was correct when it was installed so i'm guessing the belt strands dislodged it... The belt strands also look like they have wrapped around the cams and crank taking out the oil seals... Wish I could see what the inner side of the belt rubbed on....
Another update - I think I have worked out what went wrong. I just inspected the idler tensioner pulley. To my great surprise I found it totally stuffed. Brand new Nissan OEM part. I am guessing as it has so much free play it caused the belt to not run true, which pushed the belt into into the spring, which took a few good chunks out.... New one coming in tomorrow...
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
