044 is for external use, the 040 is for in tank use
The 044 will only flow as much as the 040 when mounted in tank, but will flow more when used as a extrenal pump as it was designed to do
Please explain......
Is this true? Why would mounting it internal make a difference to flow??
  • Replies 53
I would explain if I knew for sure, I am just passing on what I have been told
I have been told by alot of people, and the guy that sold me my pump, Mick at Tilbrooks etc
Have you seen either of the pumps? The 040 has a large filter/strainer at the bottom, the 044 has a small inlet for fuel hose, which people then attach a strainer too with a short length of hose, this must restrict it somewhat. I think when the 044 has to suck fuel up from the tank, and then pressurize it, and then pump it under pressure to the fuel rail it doesn't flow what its rated at. When it recieves constant flow from a surge tank or a small lift pump etc it will then perform to its rated flow, and out-perform the 040
I think its just a matter of using them for there intended purpose. In tank, the 040 is best suited and works well, and when mounted in tank the 044 works well, but apparently will flow the same as a 040 when it is mounted in the tank.
Hope this makes sense, as I am just passing on what I have been told
That said, many people are running in-tank mounted 044's but from what I understand there is no benefit in running the bigger pump unless it is mounted externally and is fed the fuel, rather than having to suck it up
Chris
What I mean is, when it is fed fuel by a helper pump - ie mounted externally out of the fuel tank as it was designed to, it will outflow the 040
When it has to suck fuel up itself, as it does mounted internally, it flows the same as a 040
What I have been told by all the people in the know anyhow
Does anybody know what colour the negative wire is coming off the fuel pump on an R33? I was thinking of doing the relay thing too, does anybody know of any negative effects of using this? anyone got photos of a relay setup?
this whole variable speed pump at idle thing really freaks me out
Chris, perhaps Mick didnt have any 044 pumps in stock at the time? :P
Can't help you out with the colours of the wires Steve
I put the pump in myself, then Mark had to re-wire it and put a relay in for me. This all happend when it was being re-mapped, before the Mick dynasty :D
yeah you can just use the std wiring, but for optimal performance its better to use new stuff, i had my 044 using the std stuff.
Steve just remove the pump and you will see all the wires in the sender and pump, its a easy job on a 32, not sure on the 33s
if you are at full noise and the one and only pump shits itself why wont your motor go bang? pumps normally dont stop they just lose pressure so any failure is not good, so two pump will give a extre chance and with big injectors 700+cc will nearly do the job.
one 044 will support the 600hp no probs but i wonto use two as there are two large fuel lines allreay on the car thanks to nissan and their hicas
remember once tuned any change in pressure will change the amount of fuel going in, so it will make it go bang if left for long enought
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
