I have decided to put one of my GTRs on the market. It is a 1990, factory dark blue. Receipts for new clutch and slotted brake rotors. New nismo engine and gear box mounts, white line camber bushes, new ball joints, AC recently serviced, engine rebuilt in Japan at some stage. It has 1.5mm os pistons, hks ssqv bov x2 with plum back fittings, apexi avc-r booster controller, n1bar inserts, polished r33 gtr rims. Tien adjustable coil overs, cyclops alarm with immobiliser, pivot turbo timer. Needs some paintwork as paint on the bonnet and one guard is starting to peel. Clean interier, no dash bubble, engine recently serviced with motul 300 v oil. rear diff bush needs replacing, will supply new bushes. Small amount of rust in bottom of rear guards. Car is not perfect but not too bad either.
$9,500.00. Ring Richard on 0416074843 with any questions.
https://www.sau.com.au/forums/topic/397901-r32-gtr-1990/
I think you priced this very well. :thumbsup:
Its not bad for 1990 car. All it needs is love. At the price someone could buy it get it repainted and it will be immaculate I reckon.
Oh and some TLC with the interior
Edited by eat_me
https://www.sau.com.au/forums/topic/397901-r32-gtr-1990/#findComment-6321725
price drop $8900 i can make it cheeper depending on how you want it ,32 ,33 wheels no rego etc happy to drop it off at transport depo.A good cheep GTR that you can drive now.
https://www.sau.com.au/forums/topic/397901-r32-gtr-1990/#findComment-6336880
yeah mate this is very cheap.. if you're not in a rush keep your price firm.. 8900 in that condition is a steal without any wheels haha.. my housemate here in Perth might be interested, will let you know
https://www.sau.com.au/forums/topic/397901-r32-gtr-1990/#findComment-6337471
How low can we go ? $7900 with a set of s15 sylvia wheels with worn tyres and no rego.Its a good driving GTR not a project, that only needs a small amount of work or just drive it the way it is.
https://www.sau.com.au/forums/topic/397901-r32-gtr-1990/#findComment-6344964
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
