Hey All,
I'm Gibbon138 but will answer to Gibbo, Gibbon, Gibbs or on occasion Jake.
I've been into rotaries for years but due to moving into an apartment and losing my garage i've gotten myself an R33 GTS25T S1 (slightly more reliable than the rotaries and way more fuel efficient)
So far the R33 has: 3.5" turbo back exhaust, pod filter, (unknown brand)piggyback ecu, and a massive terrible atmo' venting bov (yes i am getting rid of it, thanks for asking)
So this is Hi.
See you around, or out on the streets.
Cheers
Gibbon138
https://www.sau.com.au/forums/topic/397913-howdy-sau/
I'll get the minister for war and finance to lend me her camera so I can get some decent snaps, plans at this point are:
1. plumbed back BOV
2. return flow intercooler
3. airbox for the pod
4. turbo timer, defi boost+oil pressure+water temp guages
5. boost controller + wind boost out to 10psi
6. refinish the wheels (a fair bit of gutter rash on there)
7. 400r (knockoff) bodykit
8. exedy pillow button clutch
9. tien coilovers
10. project mu brakes
and we'll see how we go from there.
I'll attempt to get those snaps this week between work, more likely end up being the weekend though as i'm a night shift worker...
Cheers
G
https://www.sau.com.au/forums/topic/397913-howdy-sau/#findComment-6317656
Yeah thanks man,
The wife is pretty good with most things (it was her that told me to get my R1)
but her camera is another question entirely.
In the big scheme of things I'm hoping for 200rwkw on the stock turbo.
If I have to upgrade the fuel system etc on the way I will but that's more of a "by the way" thing than a
"Ooo ooo New fuel pump" thing.
Once I get sick of 200kw though; further mods are anyone's guess
Cheers
G
Edited by Gibbon138
https://www.sau.com.au/forums/topic/397913-howdy-sau/#findComment-6318354
For!
Love the look of it mate good work.
Mine will be full matte black with matte black rims in the next few months :yes:
Ha, good stuff man, I look forward to seeing it.
sweet, only looks good if the thing is tuckin a bit of rim, otherwise looks odd. matte black ftw!
There are a few more things than that missing but I agree she does sit a bit high at the mo'
https://www.sau.com.au/forums/topic/397913-howdy-sau/#findComment-6328254
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
