You're the 2nd person to say that recently
But I recall playing with on and wasn't even close?????
Maybe slight differences is some of the rear drive sumps
Or the guy had the wrong sump lol
Rb20 and 30 sumps won't fit from what iv heard
25 sump does fit the 26 block but a notch has to be made for the pickup I did it last week
Blake was it a Stagea block? I know they are pre-drilled for both sumps. You do need to notch out around the AWD pickup location to get the RWD sump on and then you can modify the oil pickup but cutting and brazing it to the right angle and location.
sorry for the late reply, was playing footy, f**k id be lost without you guys haha, thanks for all your input!!!! My engines a S2 RB25 with around 80k on the clock, had a RB20 that put no' 4 and 5 through the block, holy f**k it went bang! lol also VCT isnt currently connected, because im awesome at forgetting things when i built the wiring loom i forgot the vct and wiper motor hahaha, but ile have that sorted, i played with it on the dyno and gained 40hp in the mid from just connecting it, mind you it went too about 14:1 =O, my plans were a G3 Turbo from HyperGear, but i spoke too someone who knows more about turbos then most tuners in australia lol, going with the GTX30/76 and im not going to go the FFP, just hate the look of the stock manifold
Are you wanting more or less than 300rwkw on PULP? The GTX results really haven't been stellar on PULP and sub 20psi.
If you want 300rwkw or less on PULP get a run of the mill GT3076, tried and well proven for that range. Cheaper as well.
The GTX you really need to stuff more boost into it, and E85. Which will see you to 350rwkw easily with 7500rpm, but that's going beyond stock motor limits realistically if you want to last for a reasonable amount of time
Na it was a 32 gtr motor I just tiged all the pipe to make a pickup but I'm not sure on if the pickup has to be changed if you look on my build thread there are photos of it on there
I was considering just going a GT30/76, but im going to be running E85 and possibly WMI aswell so fingers crossed i wont have too run much over 18psi and i defently wont be running over 20psi lol, ile also be buying the 6boost twin scroll manifold, .82 twin scroll exhaust housing on the GTX 30/76 and a plazman manifold, 1000cc DI injectors twin 300lph fuel pumps and eventually when the S2 RB25 pops ile just buy a neo and build it, i figure ile regret buying just a GT series later down the track when i want more power.
Edited by 51NNA
If it was just a street car id get one of the Thailand made turbos from kando or hypergear but im not going too risk it, 1600 for a billet wheel hypergear or 1750 for a garret, what would you go? lol
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
