Hi there,
brought this for my build, but i have now gone down a diffrent path, its a Trust sump, with the baffle's and pick up, gives you about 1L more cap. Great for a weekend warrior or every now and than track car!!!!
PM ME or CALL msg 0413 199 018
$600 buyer pays postage
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
